First it started at the top drawer and now its at bottom one as well. If select 'normal ' program which is 111 minutes program, dishwasher get stuck and keep stopping and restarting when it comes to around 40 to 50 minutes of the program and unless i stop it it will stay in loop forever i guess. display does not show any error an only beeps every time restarts.
If I select shorter program which is 56 minutes in length it will start and finish normally.
I did clean dishwasher filters as per manual but it does not help.
Hope you can help me
Thanks
Nazzy
SOURCE: fisher and paykel leak
most likely the actuators are bad. with the unit off push and hold the lock and start buttons, lock first then start, after about 6 seconds the display will flash 188. press the power button, ho will be displayed. push the start button until Ld is displayed. open the drawer in question and push the lock button and watch the lid both sides should go down evenly, push the lock key to move it up and down as needed. push the power button to exit diagnostics. if you notice that the lid doesn't go down evenly or if one side stays up replace the actuators, they come as a pair. call a dealer/servicer to order actuators. make sure to specify top or bottom as there is a difference. hope this helps
SOURCE: Fisher & Paykel DD601 top drawer won't start.
Most likely the micro-switch that tells the controller that the drawer is closed is broken. Its a tiny little black switch at the back of the left drawer slide, it had a metal actuator that is prone to breaking.
