D-Link DES-1008D 8-Port Ethernet Switch (790069217708) Logo
Posted on Apr 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to link with 16 port switch with 8 port switch
Anonymous
Level 2:
Novelist:
  • Expert 135 Answers
  • Posted on Apr 03, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
135
Questions
0
Helped
46523
Points
371
Well it depend that which is your primary switch,for example 8 port switch is primary, in that case ,you can connect your router to one of the LAN port of 8 port switch.And connect one more cat5 cable into LAN PORT number 2 and your 16 port switch LAN port number one,then you can connect rest of computer in remaining 15 port .
Hope it can resolve your query
Thanks for using Fixya
Anonymous
Level 3:
Guru:
  • Master 513 Answers
Anonymous
Master
Level 3:
Guru:
Answers
513
Questions
0
Helped
214778
Points
1589
Good question.
To link the new switch, take a short cable from the LAN port on the new Switch and connect it to one of the existing ports on the old or connected switch. it's just a daisychain.
Just keep in mind that the LAN connection on the Last switch must be connected to a PORT on the prior device on the LAN.
2 Related Answers
Anonymous
  • 3 Answers
  • Posted on Mar 15, 2009
SOURCE: CONNECTIVITY PROBLEM WITH 8 PORT D-LINK SWITCH FOR MORE THAN 3 PC
First thanking to using d link switch
Tell me Your dns
and using pppoe ya proxy
KETAN PATEL
Anonymous
  • 198 Answers
  • Posted on Jul 29, 2009
SOURCE: D-Link DES1008D 8 port fast ethernet desktop switch
You need a router to share internet connection. You can only use this switch if your modem has a built-in router. Can you verify what modem brand and model number you have?
N68s3+ panel connection
PANEL1: Front Panel Header for Biostar N68S3+ from
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=506#dl
This 16-pin connector includes Power-on, Reset, HDD LED, Power LED, and speaker connection. It allows user to connect the PC case's front panel switch functions. Pin #1 has a black square on the motherboard and the pins are oriented from 1-8, left to right, bottom row and 9-16, left to right, top row. You will notice that there is no #11 pin.
pin #'s
1-2-3-4 Speaker (1+, 4-)
5-6 hard drive LED (5+, 6-)
7-8 reset switch (7-, 8+)
9-10-11 N/A (not used)
12-13-14 power LED (12+, 14-) ** only if power wire is 3 port connector **
13-14 power LED (13+, 14-) ** only if power wire is 2 port connector **
15-16 power button (15+, 16-)
Did this solve your problem?
D-Link DES-1008A Some ports are not connected, how the solution???
D-link 8 ports switch (modle no:DES-1008A,H/W Ver:D1,S/N:Q90K1C6008005) is not working. Pwr led is not blink. how can I trace its? Please.
Sometimes the 8 ports 1-8 stop functioning and sometimes the other 8. Presently half the switch is dead and only ports 9-16 are functional. The switch is atleast 5 yrs old can it be repaired. Rgds and...
Yes it can be repaired. You will need to hunt around for a circuit diagram for it. I have four of these old things in commission at home here and this exact thing happened to one of them. I ran a multimeter over the power supply circuit board (top left) and found one of the capacitors out of spec. The resulting limited power to the rest of the unit meant that it couldn't cope with traffic on all ports. Replaced and fixed the problem. Needed soldering iron and multimeter. Good luck, hope this helps.
Cheers
Mark Vincent
1helpful
Not enough ethernet connections, can I buy a spliter or do I have to buy another D-link with more connections.
You would be better buying a "switch" rather than another router.
you simply run one cable from the router to the switch, and the other ports are used to connect your extra PCs.
be sure to get a switch with enough ports on it. They typically come in 5, 8, 12 or 16 ports. And remember, one port on the switch will be used by the router.
How do i connect 2 d-link switches
i found that there is a MDI uplink port for cascading
Dlink DES-1016D 16-port 10/100 Switch
Product Features
  • 16 10/100Mbps ports
  • Full/half duplex support for each port
  • MDI uplink port for easy expansion Expansion is easy through a MDI uplink port. You cascade several switches together through this port to get more ports.
  • Auto-learning of network configuration
  • Flow control in full duplex mode for protection against data loss
  • Back pressure in half duplex mode
  • RAM buffer dynamically allocated for each port
What's Included?
  • DES-1016D Network Switch
  • Quick Installation Guide
  • CD ROM
Beginner in networking
um, each switch will have a starting number of open ports, it is best to choose a switch that has enough to start your project, and a few open spares, that can be used later, as you expand the network. switches are sold in a 4 port 8, 16, 24, 48, 64, 128 ports. you can also link two switches, to add more workstations, it would be better to have one switch, with as many open ports as needed, rather than linking. So plan ahead, and leave a few open ports for later upgrades
Switch is locked
Username :D-Link
Password :D-Link
OR
Username :admin
Password :admin
NetGear ProSafe FS116P 16 Port... Problem:
I had the same issue with the 8 port prosafe GS108.
open the case, look for the small (barel like shape) capacitors near the power connector.
Their top is mostly silver and should be FLAT, if it is uneven or slightly expanded as if ready to explode, that is the one that need replacement.
Best source is any old motherboard or if you prefer, buy a couple new ones.
6.3 Volt, 1000mF (micro Farad)
If you cannot determin which one is gone, just replace both or how many your switch has.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
