Follow this steps:
1.Download Windows Password Unlocker from Password Unlocker Official site
2.Decompress the Windows password unlocker and note that there is an .ISO image file. Burn the image file onto an blank CD with the burner freely supported by Password Unlocker.
3.Insert the newly created CD into the locked computer and re-boot it from the CD drive.
4.After launched the CD, a window pop up with all your account names(if you have several accounts) select one of the accounts that you have forgotten its password to reset it. Just one press, this software can remove screen password instantly.
You will reset your password easily.
Well, if you forgot your login password in windows vista, you can use Windows Login Recovery to bypass Windows vista password. And here is guide for you:
1: Start Windows Login Recovery software, select Reset local account password for Windows 7/Vista/XP/2008/2003/2000, and then click Next.
2: Insert the CD/DVD or USB flash drive into the computer. Select CD/DVD or USB, click on Burn to start burning a password reset disk.
3: The password reset disk will be successfully burned automatically then. Then click Quit when finishing burning.
Then you can use the password reset disk to crack windows vista password. It works great. Hope it be helpful.
If you forgot your windows admin password, I suggest you to remove it with windows password reset tools. I removed my windows password successfully with Windows Password Reset 9.0 yesterday. You can have a try http://www.reset-windows-password.com/reset-windows-7-password.html
Sometimesthe easiest and safest way is to just to buy a tool like WindowsPassword Seeker. It will save your plenty of time andIt is very effectively. Download it from http://www.passwordseeker.com
I forgot my windows password before, and I used Windows Password Reset 9.0 to solve it. It is a professional utility to recover windows password. With no data loss and no reinstall.http://www.reset-windows-password.com
I do not have an immediate remedy sorry, however, there is Vista Logon password breaking software on eBay, for a couple of ££'s.
Just click on Categories/Computers/Software/Utilities & you will locate the software required within the first page, more than likely.
I hope that I have been of some assistance to you.
kindest regards,
Ste
You can used hirens utility software, a bootable cd that can remove password, try check this link.
http://www.hiren.info/pages/bootcd
Remove a small coin sized CMOS battery to store all BIOS settings along with the password. To reset the password, unplug the PC, open the cabinet and remove the CMOS battery for approx. 15-30 minutes and then put it back. It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings.
Under the keyboard or bottom of laptop - If you are working on a laptop computerthe location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.
If it fails, then try to remove the battery for at least one hour.
click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password
Ebay you can purchase a
Password Unlock/Recovery For Windows 2000/XP/Vista/7
Item title Password Unlock/Recovery For Windows 2000/XP/Vista/7
Buy It Now price: US $1.49 (Approximately AU $1.50)
hope this helps
hope this helps
hope this helps
hope this helps
