The "LAMP" LED light indication still light up,after all the other LED lights indications turn off?The tv projection lamp is dead.Require a new tv projection lamp.
After i replace the lamp on my Hitachi50v500a worked everything then i turn it off.After 1h wanted to turn it on again and it shows (TEMP) light is that a lamp fan or something else.Please help how to fix it by my self.Coz no money to call the tech.
Symptom: All Front LED indicators are flashing in sequence: Power-->Temp-->Lamp-->Power......continuously Cause: Replace Lamp . This symptom may happen all the time or it may be intermittent. It is normal if it occurrs from time to time, See OG under TV Front Indicators explanation notes.
Did you ever get a answer to this question? I have a hitachi 50vs810 with the same problem. I found the same sensor "tokin ohd3-90m."
I ohmed across mine and it shows open. I then held my lighter under it and it stayed open. I suspect this part is bad so I tried jumping it out. No change. Still have the same blinking temp light.
So... in the end I don't know if I tested it right or not either. Good luck and let me know if you learned anything that can help me out.
