Rheem 81VP2S Point-of-Use Electric Water Heater, 2-1/2 Gallon, 120v Logo
Posted on Apr 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a rheem 81VP2S Electric water heater it keeps tripping the circuit breaker. If I flip the breaker back on it will run for a bit then trip again. Or the breaker will trip If I I plug it in when it is unplugged what seems to be the problem here
Anonymous
Level 2:
Guru:
  • Expert 351 Answers
  • Posted on May 03, 2010
Anonymous
Expert
Level 2:
Guru:
Answers
351
Questions
Helped
217760
Points
811
Hi , when a breaker trips immediately, that can indicate a problem in the circuit. But the circuit stays on for a bit , then trips, so there is a problem with the heater. Could be that a thermoastat or heating element is shorted out. You can replace these items yourself, I would check the heat element first. Or there may be some corosion residue around the heater terminals.
Rheem marathon tripping breaker
Turn power off. Open covers and inspect for burned parts.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
Test elements. Marathon takes specific element, and does not use generic element from hardware store.
http://waterheatertimer.org/How-to-test-water-heater-element.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
I have a rheem 40 gal electric water heater. The GFI on the tank keeps popping do you know what could be causing this
10-23-12
Your tank has a GFCI circuit breaker?
Maybe you mean ECO reset button located on upper thermostat?
If GFCI circuit breaker is tripping, turn power off, open covers inspect for burned parts, and test elements. Copy following link for troubleshoot walk-thru:
If ECO reset button is tripping, then replace both thermostats, and test elements.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Electric shower just installed cuts out at fusebox after being on for about a minute
10-20-12
Circuit breaker is tripping on electric shower?
This could be absolute danger until more information is known.
1) Breakers trip because they sense heat, because the wire size is too small, or breaker size is mismatched with wire. Or breaker is loose on busbar.
Copy following links to determine correct wiring and breaker:
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
GFCI circuit breaker will trip because of same heat condition described above, and also trip if ground fault is detected.
Water leaking into element will trip GFCI.
Absolutely you need to get this problem fixed before shower is put back into service.
Call electrician, or the installer, or the manufacturer, or all.
http://waterheatertimer.org/How-to-wire-GFCI.html#spa
Rheem 50 gallon Electric Water Heater 81V52D C repair ideas needed
It could be element shorted to ground through steel tank, so don't touch tank when breaker is ON.
Or you have undersized 12 gauge wire and 20 amp breaker and the heat has loosened breaker on the busbar. Breaker trips when heat exceeds breaker limit. Jiggle breaker and listen for crackling sound.
To restore hot water now:
Turn off circuit breaker, and open top cover then Push in reset button on top of heater to restore functionality. Put back insulation and factory cover.
To fix water heater: test and replace bad element.
If problems continue
http://waterheatertimer.org/Troubleshoot-household-electricity.html
Water heater tripping the breaker
Copy following link for troubleshoot walk-thru for electric water heater tripping breaker:
No hot water
You posted under Rheem 40 gallon electric water heater, which is two-element 240Volt heater.
If this is not your heater, add a comment.
If you suddenly have no hot water, that narrows the suspect list.
Step1:
Check for tripped circuit breaker.
Open top cover on water heater and push in reset button on upper thermostat.
If reset button is tripped out, and will not push back in, then replace upper thermostat.
Put ear against tank and listen for bubbly-fizzing sound that says heater is ON.
If reset is not tripped, then move to step 2
Step 2: use tester or multi-meter and test across top two screws on upper thermostat for 240Volt.
If heater is not getting 240V, then test circuit breaker.
Move water heater wires from 240V breaker to another same-amp 240V breaker and see if that restores power.
You may need to replace breaker:
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
If problem persists, then you might have a line problem between breaker and water heater.
Open cover on top of heater, and check connections on top of heater.
Step 3:
If heater is getting 240V, then upper thermostat or upper element is bad.
I suggest 30 minute troubleshooting which could save you a service call, and will be valuable information in the future:
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
I have a model 71-408 B which just stop heating
If I understand correctly, you have electric water heater.
Heater suddenly stopped heating.
Four things cause sudden loss of water heater.
1) Reset button located under the top cover is tripped > turn off power, remove cover, press reset button > if reset keeps tripping, go to the troubleshooting link shown below.
2) Electric power to heater is interrupted > check circuit breaker > test for voltage > look for loose wire on breaker
3) Upper element burned out > test and replace element
4) Upper thermostat bad > replace upper thermostat
Reset button is best suspect.
Here is a link for complete troubleshoot and homeowner repair of electric water heater:
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Top Rheem Water Heaters Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
