You should be able to buy a good quality cord at your local hardware and be on your way
You should be able to use any decent (i.e. thick) outdoor power cord. The trick with the disconnecting problem is that there is a nobby bit on the switch housing that you are supposed to loop the cord around. The cord plugs into the bottom of the switch housing and then you are supposed to push a loop of the cord up and over the tab on the outside of the handle.
Thank you for your advice. I have done that previously, however, the generic replacement cord keeps on getting disconnected every minute or two whenever the power is turned on and I start mowing!
