Honda Pressure Washer PSI 3000 Logo
Posted on Apr 02, 2010
Engine quits running after start
I have a honda pw with a B&S 6.5 Quantum engine and it will run for about 20 seconds and shut off. Initially it would run for a minute or two and shut off but that time keeps getting shorter and shorter. I have checked oil level and I am good...
What could cause this?
Anonymous
Level 1:
Champion:
  • Contributor 435 Answers
  • Posted on Apr 08, 2010
Anonymous
Contributor
Level 1:
Champion:
Answers
435
Questions
0
Helped
138226
Points
44
It can be probably the spark plug,change the spark plug.
2answers
IT WILL STaRT , RUN FOR 1 MINute AND SHUT OFF BUT WAS rUNNING WITH COVER OFF BUT NOW HAS STOPPED THAT IT WILL RUN FOR 20 SEcONDS AND SHUT OFF
What would cause 1995 Chevy blazer to run for 20 minutes ...
answers.angieslist.com > Auto > Auto Repair & Service
Mar 30, 2014 - For example, can you start the car cold, it will warm for 20 minutes, and shut ... While not a car, my Motorcycle (also fuel injected) would run for a little bit and shut off. The issue ... Answered 1 year ago by WoWHomeSolutions.
Car starts and it shuts off/loses power - CarGurus
www.cargurus.com > Questions > Audi > A4
CarGurusJun 20, 2013 - Car starts and it shuts off/loses power - I have a 2003 Audi A4 Turbo.93K on it. ... \n check out these few options 1. loose or faulty electrical connections at, .... After drying it for a few minutes and cleaning with a dry cotton cloth, I have ... you can't fill your car while its running the gas tank is a vacum while its ...
Car starts then dies in a few seconds - CarGurus
www.cargurus.com > Questions > Ford > Crown Victoria
CarGurusFeb 3, 2014 - Car was running fine, and then engine stops. ... 1 out of 1 people think this is helpful. ... my car will start run for a second an shut off . ... under load, dies,starts 15 minutes later, runs fine then stumbles and dies again 3 answers.
Chevrolet Silverado 1500 Questions - Engine Shutting off ...
www.cargurus.com > Questions > Chevrolet > Silverado 1500
CarGurusMay 20, 2015 - Engine Shutting off after about 10-20 seconds on 2004 Silverado ...When the engine is hot, two things occur: (1) thermal effect on .... my 2000 chevy silverado just randomly die then it will start back up idle .... It will run fine for 15minutes. ... run down behind or beside the powersteering pump, that the car will ...
When I run my Honda gx620 pressure cleaner/
Over heating, do you really need to run it for 3 hours in one shot???? Try one hour then let it cool down!!!
Humming after engine shuts off
I'm no Honda expert so I'm not sure if an 02 has a "key off" evap system. If it does that may be what you're hearing. A lot of newer cars will run evap tests while the vehicle is off. It basically pulls vacuum on the fuel tank with an electric motor to test the integrity of the evaporative emissions system and opens / closes vacuum switching valves.
Northstar PW shuts off hot if washer is moved. Honda engine
Being petrol driven, it may have a mercury kill switch which puts a ground on the ignition circuit stopping the engine if you move it. Perhaps for safety in case you overturn the unit somehow.
My 50 cc dirt bike is messed up will start but won't runbutabout 10 seconds the engine bogs up then shuts down
Hi and welcome to FixYa,
Initially, determine the quantity and quality of the fuel by loosening the drain screw and catching the fuel draining. Additionally, determine if there is spark right after "engine bogs up then shuts down".
The "quantity and quality of the fuel" would be indicative if the fuel is contaminated and/or if there is sufficient fuel in the carb's bowl to run the engine above 10 seconds. Checking for the presence / absence of spark after the engine quits would help you determine if it is an electrical problem or a fuel starvation issue.
Good luck and thank you for asking FixYa.
2answers
Engine Floods after brief start and run when cold -then shut off
Local mechanic determined engine was flooded and started it by holding throttle to the floor and cranking 5-7 seconds - then the engine sputtered to life. It has run perfectly before and since and I'm at a bit of loss to understand why this occurred this one time - so far. It's been driven now 5 days with no problems.
Top Honda Garden Experts
Sean Wright
Sean Wright
john h
Jesse Walters
Jesse Walters
Are you a Honda Garden Expert? Answer questions, earn points and help others
