Simplex Kaba Ilco Unican  L1000 keyless lock  Logo
Posted on Apr 02, 2010
I have a Unican 4000 series electronic door lever lock with no manual and I need to change the code??? Can you point me in the right direction...thanks
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Mar 08, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3961
Points
Unican 4000 factory-default master code is 12345678
Change handing on unican 4000 electronic lever lock
go intp maintainance mode 01 then go through to 08 it will tell you itself
2answers
How to change handing on inner side of a Unican 4000 caba by Ilco
should be on door lock either on remote or when drivers door locked unless a door is ajar or light is on in the car
Simplex 1000 lever handle when correct combo put in lock combo lock operates fine except unless you let the lever snap back lock dose not reset in locked position, in other words if you slowly let the...
I don't have a direct answer, but here is the contact info you need for customer service:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
1-800-849-8324 (option 1)
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Technical Support (Simplex, E-Plex, PowerLever, 4000 Series, Solitaire 850L, Solitaire 850/950)
1-800-849-8324 (option 3, and then option 6)
Tech Support is probably your best bet!
Iv'e got a Simplex L1000 series combination that needs the Outside Lever Assembly-Right Hand and Outside Sleeve Assembly changed on it. I have the parts needed but I can't figure out how to remove the...
Here is a link to the Kaba Ilco web page which has a grid chart, including the L1000 series lock:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
Of particular interest to you will be the Manual (page 10) and Parts List, which shows an exploded view of the lockset. Hopefully this will give you the info that you need.
On the same webpage you will also find a link "Contact Us" for further technical information and parts.
Also on that page is a link to get Adobe Reader. If you don't already have it installed on your computer, you will need it to open the PDF files for the manual and parts list.
Hope this helps. Good luck!
1helpful
2answers
How do I remove a unican L1000 lock from the door? I have the upper lock cylinder out, and used the spanner wrench to remove the ring on the non entry side. How do I get the handle off to remove the lock...
use the other side of the spanner wrench with the point and insert it into the hole in the inside sleeve and you will feel some spring tension.........push in the tool and pull the handle off at the same time.
How do I change the combination to a Unican 1000 Right Lever cipher lock
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE
DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE
O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE
THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS.
REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a
maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND
CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH
SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59
CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
You will find a link to download the manual for your model on this page:
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
Customer service can be contacted from this link:
2helpful
How do you change the handing on a unican 1000
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13&obj=1000
you can download a manual here. I assume you mean to change from left hand door to right hand door? The manual will describe how to do that.
2answers
How to reset codes in Kaba ilco Unican 4000 access control
I have a Unican 4000 series door lock and need to find code for it
4helpful
Lost code for keyless unican lock
I just performed this on my lock and it's quite simple. The instructions are in the attached manual.
http://www.kaba-ilco.com/access_control/access_download.aspx?File=simplex_1000_installation_instructions_d8_pkg_2280.pdf&Attachment=True
Cheers.
8helpful
4answers
Bought house from bank and trying to retrive lock combination
I'm trying to remove a unican lock from my door but I can't see how to get the handle off. any suggestions?
Top Simplex Locks & Locksmithing Experts
Steve Pack
Steve Pack
ADMIN Eric
ADMIN Eric
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
