2001 Ford Taurus Logo
Posted on Apr 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cant figure out how to remove old window rail screws to replace window
Anonymous
Level 2:
  • Expert 123 Answers
  • Posted on Apr 12, 2010
Anonymous
Expert
Level 2:
Answers
123
Questions
0
Helped
58097
Points
246
There most likely quarter inch rivets. I have a 2000 taurus and had to replace to windows they were put in with two rivets each. The easiest way to get them out is to use a 1/8 or 3/16 drill bit and drill them out. If you don't have a rivet gun just go and buy 1 inch long 1/4 bolts with a washer on each side and they will fit perfect in the existing holes.
How do you replace a coil on a 99 5.7 vortec?
It is held down with 2 screws and lightly twist it when removing it.
The exterior door handle on my 1993 Nissan pickup broke. I have a new handle but can't figure out how to remove the inside door panel to get to the area where I can remove the old handle and replace with...
Inside door handle should have some screws that need to be removed and the window crank will have a c-clip behind it . or some you have to pop the cover off the window crank
How to replace subaru quarter glass
Hi Mom, I'm wondering how your spinach pie tastes? Replacing the quarter light is not an easy job, but if you're handy with wrenches and screw drivers here goes. Open the offending door and remove the power window switch by gently lifting it with a thin flat screw driver. Disconnect the cables by releasing the locking tap on the underside of the unit. Remove the back cover of the door release handle by either removing the single screw or un clipping it, Using a Philips screw driver, remove the two deep screws under the arm rest. Borrow the pastry knife from your kitchen and at the lowest part of the door insert it between the panel and the door frame, and then gently pry it towards yourself until you hear the press studs pop open. Repeat the same action all the way around the bottom and up the two side of the door and when loose, lift off the panel and place it out of the way of the kids. Re attach the switch controlling the window and lower the window to where you can reach the bolts (10mm) with a socket wrench. The bolts hold the regulator to the window. Loosen them and remove and lower the regulator all the way down, until you can pull the window up at an angle allowing you to remove it from the door. carefully lift and remove it and put it somewhere safe. remove the rubber weather strips and from the top of the door frame together with the strips inside the rail the window moves on. If you follow the rail of the window to where it is fitted to the door frame you will see another 10mm bolt at the bottom. Before removing that one mark the position as exactly as possible. (The position is critical for smooth operation of the window). Remove the weather strip around the outside of the frame of the door and on top you will see the upper bolt holding the rail (which should also be marked) Remove that and then the rail. The quarter light is held into position by a rubber which surrounds it.Being very careful of any glass which may have remained in the rubber gently remove it and after cleaning it, fit the replacement into the rubber. With the glass in place fitting it into the correct position is not going to be easy. A good idea is to smear a light coating of white petroleum gel onto the parts of the rubber which fit into the door frame before fitting it. When the quarter lite has been fitted and the rail placed in position reassembly is opposite to disassembly. Keep in mind that when fitting back the window it must be aligned with the rails which should be finally tightened after the window is fitted. Now tell me, while you're busy doing that, who's gonna bake the spinach pie? Best regards John
1helpful
Cable system on passenger door power window, 1999 dodge Caravan, has slipped off track. Need exploded diagram to restore to original.
REMOVAL
1. Remove the watershield. (Refer to 23 - BODY/DOOR - FRONT/WATERSHIELD - REMOVAL)
2. Remove door glass retaining clips and secure the window in the up position using masking tape or equivalent(FRONT DOOR GLASS CLIPS).
3. Disconnect wire connector from power window motor, if equipped.
4. Loosen screws attaching front and rear window guide rails to inner door panel (FRONT DOOR MANUAL WINDOW REGULATOR - TYPICAL).
5. Remove screw heads on guide rails from key hole slots in inner door panel.
6. Loosen screws attaching regulator to inner door panel.
7. Remove regulator from inner door panel.
8. Extract rear guide rail through inner door panel rear access hole (FRONT DOOR POWER WINDOW - TYPICAL).
9. Extract front guide rail through front access hole.
INSTALLATION
1. Insert front guide rail through front access hole.
2. Insert rear guide rail through rear access hole.
3. Place window regulator in position on inner door panel.
4. Place screw heads on guide rails in position through key hole slots in inner door panel.
5. Tighten screws to attach front and rear guide rails to inner door panel.
6. Connect wire connector into power window motor, if equipped.
7. Install door glass.
8. Verify door glass alignment and operation.
9. Install sound shield and door trim panel
DIAGRAMS CAN BE FOUND ON JUSTANSWER,COM
2helpful
Need to remove door panel on 1984 thunderbird and this old man cant figure it out
To remove the door panel, remove any screws that are in the vicinity of pull handles and door pockets. These screws will be under little trim covers that you need to prise off to get to their heads. Look for the screws around the edge of the panel and also the screw in the latch release handle recess.
The lock knob, if there is one there, will have to be screwed off and then carefully work your way around the door, freeing the panel's clips from their holes in the door frame. (Doot panels are brittle and clip break out easily).
Finally the panel will probably have to be lifted out if the window slot. (If the panel does not come off, work out what is retaining it and remove that screw or slide it off the clip that is still holding the panel. Disconnect any electrical plugs behind the panel. Under the panel you will find a plastic dust sheet that is stuck to the door frame, remove this carefully, you will have to replace it before replacing the panel.
3helpful
Problem with the 2004 Land Rover FreeLander How to install a Freelander Window Regulator with cable loose not broken just off winder
Tools you will need:
1. Panel removal tool
2. Philips screw driver
3. 1/4 Ratchet with extension and 8 mm socket.
4. grease to lube new regulator. The first thing, is to remove the door panel:
1. Remove 2 screws securing hand rail to door.
2. Remove screw securing door handle escutcheon to door and remove the escutcheon.
3. Remove 4 screws securing pocket to door.
4. Carefully release 10 clips securing trim casing to door. (Best to use a door panel removal tool, the plastic clips break very easy)
5. Disconnect multi-plug from upper door speaker. Do the same for lower speaker
6. Remove trim panel from door.
7. Remove the plastic vapor barrier , care full not to destroy. (You may have to cut around some things such as the hand rail brackets.)
At this point you will be able to see the regulator and motor through the small holes in the door. At this stage a small flash light is very handy
to see such things as the power connector for the window motor.
1. Loosen the two bolts in the slotted holes, shown above.
2. Remove the remaining 4 bolts securing regulator assembly to door.
3. Lower glass and loosen the 2 bolts securing door glass to regulator. Then slide the channel bar forward to remove.
4. Disconnect the power from the window motor.
5. lift the window and secure in the up position ( I used Duct tape).
6. Collapse all the arms and maneuver the old regulator out the center hole in door. Assembly is basically the reverse of the removal procedures:
1. take the two screws that you partially removed out of the old regulator and install them partially install them into the new regulator.
2. Work the new regulator through the center hole.
3. Connect the power to the regulator motor.
4. Lower the window glass, take the channel that secures the glass to the regulator, insert it over the tow bolts that were loosened in step 2 above
5. Raise the window and secure.
6. Insert the 2 bolts on regulator through the keyed holes in the door and finger tighten.
7. line up the rest of the bolt holes and install the remaining two bolts in both the regulator and then tighten two bolts in step 6 above
8. install the two in the bottom channel.
9. Now is a good time to test..........
Then all that is left to install the hook up the speaker(s) and mount the door panel.
1. Position trim panel close to the door and connect door speaker(s) multi-plug(s).
2. Secure door panel to door with clips.
3. insert escutcheon to door handle and secure with screw.
5. Fit pocket to door and secure with four screws."
1helpful
Trying to reinstall the roof cargo racks on the rails of a 01 jeep cherokee my son took off and cant remember to put on
That's usually easier to do if you remove one side rail.
There are usually six access holes in the rail that the screws go into. (pretty sure the screws are torx type) Once the rail is off, you can easily attach the cross bars and re-attach the rail to the roof. Ends of cross bars are held on with a screw that goes in from the bottom side. When replacing roof screws it is good to put a dab of silicone sealer on each screw hole to prevent rust or leaks.
1helpful
Drivers door window is off it's carrier Rail
Remove screws by mirror, and around the door armrest, use a flathead screwdriver to pop out the electric window/door lock controls and unplug the wire harness. Now take a bigger flat head screw-driver and pry around the edge of the panel where there are little plastic retaining screws. Pull slowly and make sure screw-driver is directly next to plastic screw. Now, pry all around the edges, and pull the panel straight up and pull than set it on the ground. You will now see the inside of your door. There may be plastic covering over the door that you will have to slowly pull off or cut. Now you will see your window. There should be a carrier rail on each side of the widow or straight across the bottom holding window in place. Re-align window to holder, (if there is any broken parts, you should get them replaced) You can turn car power on and still use and re-plug in window control buttons to help adjust the carrier rail.
Now reverse procedure for replacement.
11helpful
3answers
How do i replace the window motor
This is a common problem with driver side window. Its just a wear and tear problem. Don't go to the dealership, the Regulator will cost you over $230. Go to Amazon.com and search for the part number which should cost you only $70-80 or so. If you go to a glass place they will charge you dealership price plus $150 per hour. I say do it yourself which goes a little something like this.
TRIM PANEL
REMOVAL
(1) Remove the plug and remove screw attaching
door pull cup to inner door panel.
(2) Remove switch bezel and disconnect power window/
memory switch.
(3) Remove screws attaching trim panel to door
from below map pocket.
(4) If equipped, remove window crank. (Refer to 23
- BODY/DOOR - FRONT/WINDOW CRANK -
REMOVAL)
(5) Remove screw holding door trim to door panel
from behind inside latch release handle.
(6) Disengage clips attaching door trim to door
frame around perimeter of panel.
(7) Lift trim panel upward to disengage flange
from inner belt molding at top of door.
(8) Tilt top of trim panel away from door to gain
access to latch linkage.
(9) Disengage clip attaching linkage rod to inside
latch release handle (Fig. 13).
(10) Separate linkage rod from latch handle.
(11) Disconnect the power door switch, courtesy
lamp electrical connectors.
INSTALLATION
(1) Hold top of trim panel away from door to gain
(2) Place linkage rod in position on latch handle.
(3) Engage clip to hold linkage rod to inside latch
release handle.
(4) Place front door trim panel in position on door.
(5) Install trim panel into inner belt molding at
top of door.
(6) Install clips to attach door trim to door frame
(7) If equipped, install screw to attach door trim to
door panel behind inside latch release handle.
(8) If equipped, connect power switch into wire
connector.
(9) Place power accessary switch in position on
door trim.
(10) Connect wire connector into memory seat/mirror
switch and install switch into trim panel.
(11) Install screws to attach accessary switch
panel to door trim.
(12) Install screw cover into switch panel.
(13) If equipped, install window crank.
(14) If equipped, install screws to attach trim
panel to door inside map pocket.
(15) If equipped, install screw to attach door pull
(16) If equipped, install screws to attach door
assist handle to inner door panel.
(17) Connect wire connector into courtesy lamp.
(18) Install lamp in door trim.
(19) Install switch bezel.
WINDOW REGULATOR
REMOVAL
(1) Remove the watershield. (Refer to 23 - BODY/
(2) Remove door glass retaining clips and secure
equivalent (Fig. 15).
(3) Disconnect wire connector from power window
motor, if equipped.
(4) Loosen screws attaching front and rear window
guide rails to inner door panel (Fig. 16).
(5) Remove screw heads on guide rails from key
(6) Loosen screws attaching regulator to inner door
panel.
(7) Remove regulator from inner door panel.
(8) Extract rear guide rail through inner door
panel rear access hole (Fig. 17).
(9) Extract front guide rail through front access
hole.
INSTALLATION
(1) Insert front guide rail through front access
hole.
(2) Insert rear guide rail through rear access hole.
(3) Place window regulator in position on inner
door panel.
4) Place screw heads on guide rails in position
(5) Tighten screws to attach front and rear guide
(6) Connect wire connector into power window
motor, if equipped.
(7) Install door glass.
(8) Verify door glass alignment and operation.
(9) Install sound shield and door trim panel. __________________
Avatar: EconoVoyager Concept
2001 Dodge Grand Caravan Sport 3.3L
1993 F-250 Vent windo broken
It's been along time but I think I remember the weather strip and all coming out together.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
