Pramac GBW30P Encl Diesel Genset w/Perkins Eng Logo
Posted on Apr 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the size Battery (cranking amp) needed for a 3990cc 4 cylinder Perkins 50HP AA Series Naturally Asperated Diesel Engine With a 40KW Generator attached. Thanks, Verner From Florida.
Starlight Power
Level 2:
Sergeant:
  • Expert 117 Answers
  • Posted on Sep 27, 2018
Starlight Power
Expert
Level 2:
Sergeant:
Answers
117
Questions
0
Helped
96361
Points
657
No matter it is 40KW Perkins generator, or other brand of generator, like Cummins and Volvo, the battery capacity is 24V DC in total. (One battery is 12 V, generator needs two batteries.)
About battery introduction and maintenance, you can refer to this article. https://www.dieselgeneratortech.com/generator-sets/introduction-and-maintenance-of-genset-start-up-battery.html
Anonymous
Level 1:
New Friend:
  • Contributor 8 Answers
  • Posted on Jun 04, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
8
Questions
0
Helped
6487
Points
10
Use a 120 amps battery
Fred Yearian
Level 3:
  • Master 5,603 Answers
  • Posted on Apr 02, 2010
Fred Yearian
Master
Level 3:
Answers
5603
Questions
Helped
2250249
Points
16163
If the unit has a battery box, measure it and get the largest size that will fit and of course the correct voltage. Diesels take a lot to crank.
You can search battery sizes on the internet for physical size. NAPA has a pretty good selection.
I need the workshop manual of perkins england 2332/1800 diesel engine of genset generator Olympia Gep150 controlled by Fg wilson uk.best regards
We are Perkins diesel generator OEM and can provide 22KW to 1800KW Perkins diesel generator including open type,silent type and container type genset. Each genset has its user's manual.
Normal starting procedure of Perkins Generator set
1. As far as possible do not start the generator set under load conditions.
2. Transfer the key switch to the starting (STAR) position. The engine should start immediately.
3. After the engine starts, return the key switch to the running (RUN) position. If the engine has not started after 10 seconds, turn the key switch back into operation and (RUN) for 10 seconds. Then repeat steps 2 and 3. If the engine is still unable to start after three attempts, please find out why.
4. After engine starts, follow steps 4.a and 4.b.
A. Check the oil pressure.
B. Check the machine for leaks.
C. Make sure the battery is charged.
D. After running the engine for five minutes, check the generator monitoring system. Make sure the engine works properly before loading.
Note: do not use ether-like spray starting aids in cold weather. Otherwise, it could lead to explosion and personal injury.
The use of water jacket heaters or extra battery capacity improves the machine's start-ability below 10 ?.
Methods for checking and cleaning the core of the rear cooler of Perkins generator set
Check for damage, corrosion, dirt, grease, insect stains, leaves, oil and other debris on the cooler. Clean the cooler if necessary.
https://www.dieselgeneratortech.com/generator-sets/Instruction-for-Perkins-Generator-Set-Maintenance.html
2answers
How to remove starter from a 4 cylinder perkins engine
Search Results
    [PDF]Perkins 4-154 Shop Manual
    www.kp44.org/ftp/Perkins_4-154_Shop_Manual.pdf
    88 Perkins. Engines workshop manual. 4.154. PRINTED lN U.S.A. .... removal, dismantling, assembly or refitting of a part is straightforward ... The ENGINE NUMBER is located on the cylinder ... starter motor, air cleaner, but without clutch. lb kg.
    Reliability built into starter motors - Perkins Engines
    www.perkins.com/en_GB/.../starter-motors.html
    Perkins EnginesYou can rest assured that your genuine replacement starter motor will work ... 4 Cylinder · 6 Cylinder ... You can learn more about these cookies and general information about how to change your cookie settings by visiting our Privacy and Cookies page. ... This need for dependability is why we test each of our starter motors.
Hard starting for 1300 series perkins generator
After using a diesel generator for a long time, some malfunctions may occur that will cause the generator fail to start. What can you do when it happens?
If diesel generators fail to start, you can analyze the causes from fuel system failure, electric starting system failure, insufficient compression pressure in the cylinder and the low ambient temperature and other factors.
https://www.dieselgeneratortech.com/diesel-generators/why-diesel-generator-fail-to-start.html
2answers
Pramac 25 kva perkins encl diesel genset will not start red light on triangle on check list
Hello. Maybe you have solved your problems. But I still want to share the helpful article to you. https://www.dieselgeneratortech.com/diesel-generators/why-diesel-generator-fail-to-start.html
We are Perkins diesel generator OEM. Can provide 22KW to 2200KW diesel generator set with Perkins engine. https://www.dieselgeneratortech.com/perkins
1helpful
2answers
Valve Clearance perkins generator 275kva
We can provide 275kva Perkins diesel generator with air filter,fuel filter and oil filter, muffler, battery, circuit breaker, ATS, daily fuel tank enough to run 8 hours. And all the spare parts of Perkins engine. CE/ISO approval.
Perkins 20 kva diesel generator runs and stops in about 2 minutes.alternator failure is displayed on screen.
Ensure any engine control switch is set to the run position, with the load disengaged. Manually set the air shut off valve (if fitted) to the run position (see Fig. 18), Turn the key switch to the start position, which will energize the solenoid allowing the engine to crank over for a few seconds then start.
Check the instrument panel is showing normal running oil pressure, and the ammeter for charge to the engine batteries.
Allow the engine to run for five minutes checking the instruments are reading correctly. Stop the engine and check the oil and coolant levels, replenish if necessary.
https://www.dieselgeneratortech.com/generator-sets/normal-starting-procedure-of-Perkins-generator-set.html
2answers
Perkins engine
5helpful
5answers
MY Perkins generator 2300 series crank but can not start
I take it it's diesel. Have you renewed filters? Bleed fuel system Make sure there is plenty of diesel flowing out of tank (pipe not blocked) Check lift pump working
1helpful
3answers
Diesel mixed with oil in the sump
You run again the generator but before running, check & mark the oil level. Then stop the generator & wait until the oil settle to the bottom of oil pan. Check the oil level again & if the oil level is higher than the marking before that's means you have an engine gasket leak.You need to replace that gasket.
Top Pramac Electrical Supplies Experts
littlewheel
Ngoro
john h
Are you a Pramac Electrical Supply Expert? Answer questions, earn points and help others
