a number that long looks like a serial number rather than the Model Number. I doubt the temperature alarm can be disconnected. You _may_ be able to remove the sounder, but don't forget, it is provided for your safety and stop all your food spoiling unannounced. If the alarm keeps going of, it is for a reason and needs fixing.
The SUPER button on a Skandiluxe chest freezer is typically used when you need to freeze food quickly, such as when you've just added a large amount of unfrozen food to the freezer. The SUPER function causes the freezer to operate at its coldest temperature for a period of time, which helps to freeze the food more quickly. After the desired amount of time, you can turn off the SUPER function to return the freezer to its normal operating mode.
The compressor won't burn out just because it's running all the time. The plastic fascia pops out easily from behind(take the little panel off on the side) Set the thermostat to the middle of its range and switch the fast freeze off.
Warning light (red)
If the temperature warning light (4) lights up, it
indicates that the temperature within the freezer has
reached a level where the safe food storage is no
longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to
a safe level for the storage of frozen food.
Temperature acoustic alarm
This appliance incorporates an alarm which gives off
an audible signal whenever the warning light comes
on. This signal can be temporarily stopped by
depressing the push button for fast-freezing (6).
The fast-freezing push button can be released as
soon as the warning light is off.
Open door acoustic alarm
This appliance also incorporates an alarm which
sounds if the door is left open for more than 60
seconds. The signal will be stopped when the door is
closed again.
Hi, As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
