Mistakingly changed the command code from dvd3 to dvd2 on the dvd recorder. The dvd recorder does not respond to remote control anymore. How do i get the box responding to the remote control?
Any help will be appreciated.
If you have changed the command mode on your recorder and now find the remote no longer works. Make sure you have a new set of batteries in the remote. 1. Hold down the enter button on the remote. 2. While holding down enter button, enter the command mode code number using the number buttons. DVD1 press number button 1 DVD2 press number button 2 DVD3 press number button 3 Hold down both the number buttons and ENTER at the same time for more than three seconds. The default setting is DVD3 so try DVD1 or DVD2 to regain control.
Press stop button then the power button together the player will go off. put it on again the remote should work.
my dad mistakenly changed the command mode from DVD 3 to 1 and the remote controller is not responding to the box. I have tried pressing the stop button and then pressing the power button together and it turns off, but when i switch it back on, the remote controller still does not respond.
what shall i do? any more suggestions?
pleaseeee
same problem remote will not work with dvd player but switching off holding both buttons and then switching back on does not make the remote work heeeeeeeeeeeeeeeeeeelp
