The "DNS error 80710102" is an error displayed on the Sony Playstation
when attempting to connect to the Internet. It's a known problem for
Playstation users, but the answer is to disable universal plug-n-play
on the router.
Step1
Open
a browser window and enter the router's IP address into the navigation
bar. For most routers, the default IP address is 192.168.1.1.
Step 2
Enter
the username and password used to access the router. Press "OK" and the
console application will be shown in the browser window.
Step 3
Click the "Password" tab. The UPnP settings are located in the same window as the router's password settings.
Step 4
Select
"Disable" from the box labeled "UPnP" and click the "Save" button.
Close the router's console window. Start the Playstation machine and
SOURCE: HELP PLEASE
You need to sign up to the ps3 wireless play just like xbox live but without paying. go to the sony website to find all the info.
SOURCE: dns server error
is it an older game?
if it is then its because the website group hosting that game has stopped because not enough people play to keep the dns system up
SOURCE: DNS error 80710102
If you receive an eight digit 800 series error code, there may be a few solutions.
Update the System Software.
Visit Playstation 3 System Software Update to download and install the most recent version.
To check what version of the System Software is currently installed on your PLAYSTATION 3:
1. From the XMB home menu, go to (Settings) > (System Settings) > [System Information].
2. The system will display the System Software version number.
Power-Cycle all Network Equipment
Power-cycle means to turn the networking devices OFF (i.e., unplug
it from the power source), and then to turn it back ON after a set
period of time. This will allow the network devices to refresh its
settings.
Please power-cycle ALL of your network equipment, including any
wireless access points, routers, Voice Over IP (VOIP) modems, and
broadband modems for two (2) full minutes. After 2 minutes, you can
turn on (or plug in) your equipment.
Check Your Enviroment
Restore Default Settings
During certain troubleshooting situations, it may be
necessary to restore all of the PLAYSTATION 3 system settings back to
their original "default" configuration.
IMPORTANT
You will need to go through the initial setup screen before you can use the PLAYSTATION 3.
The Restore Default Settings feature will erase any previously saved
settings and restore all of the following settings to the default:
Also, do not confuse "Restore Default Settings" with the "Restore
PS3 System" option (the next option down on the menu). The "Restore PS3
System" will not only restore the default settings, but it will also
delete all hard disk content (You will lose all saved content from your
PS3 system's hard drive if you use "Restore PS3 System.
If all these fixes fail to work you can contact sony at:
http://www.uk.playstation.com/Support/PS3
or
http://www.us.playstation.com/help-support/PS3
Hope this helps.
