2wire Wireless-G 802.11g ADSL Gateway Logo
Posted on Apr 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I reset password on my gateway 2 wire?
Anonymous
Level 3:
Guru:
  • Master 513 Answers
  • Posted on Apr 02, 2010
Anonymous
Master
Level 3:
Guru:
Answers
513
Questions
0
Helped
214783
Points
1589
I need the model number of the ADSL device. Is it a router, an ADSL/Router/Switch or ?
Is the make Gateway?
Each device has its own reset method.
One: Try pressing and holding the reset switch for ten seconds.
Two: Try turning off the power, hold the reset switch, plug the unit back in and hold the switch for 10 more seconds.
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2557471
Points
31058
Straighten a Norwegian paper-clip,
and insert the end into the small hole in the back of the 2WIRE, to "reset" the unit to its "factory" settings, including the "default" ID/password.
Then, reconfigure your wireless network.
How reset login password for gateway windows 8 desktop computer?
Right click My Computer to select Manage option. Or press Windows + X to choose Computer Management. Step 2: Reset the password for Windows 8 user account. Click Local Users and Groups Users, and right-click the account you want to reset its password, then choose Set Password option in the pop-up menu.
tip
How to Reset Gateway Password?
How to reset Gateway laptop password? I forgot my PC password Gateway Windows 7, I want to unlock laptop password urgently! Can you help me recover my lost power on password for Gateway? Now, we together share some ways to remove Gateway admin password.
Optional 1: DIY a CD/DVD/USB password reset disk instantly to recover lost Gateway password
The method is the most effective solution to get out of Windows password problem. It just needs burn an .iso image file to one of these media. Now, take one of most popular Windows Password Recovery tool as example:
A. Download Windows Password Recovery and burn its .iso file into a blank CD/DVD or USB Flash Drive on an accessible PC;
B. Boot the burned CD/DVD or USB Flash Drive from the PC lost password;
C. Reset a new Gateway password.
Whatever for Gateway Windows 7, Vista, XP, Server 2000, Server 2008, etc. the above Ainorsoft Windows Password Recovery has its different versions to suit for these OS.
Optional 2: Gateway password recovery disk helps remove lost laptop password
It is the most convenient way to retrieve Gateway PC password and while, is maybe suitable for little part of computer users. The Gateway recovery disks should be created once our Windows account is created. Also, one account password responds to one password reset disk. Take Gateway Windows 7 as example:
A. Insert a CD/DVD/USB Flash Drive into the driver.
B. Click Start - Control Panel - User Accounts and Family Safety - User Accounts.
C. On the left pane, select "Create a password reset disk" - "Forgotten Password Wizard".
D. Click "Next" and follow the Wizard to create password reset disk.
Now, the Gateway Windows 7 password recovery disk is created. When we need break Gateway Win 7 laptop or notebook password on the login screen and input an incorrect password, click "Reset Windows Password" and insert the password reset disk. The Password Reset Wizard will help you create a new password to override lost Gateway password.
Optional 3: Reset Gateway password by accounts with administrative privileges
Accounts with administrative rights or the default and built-in account can help us to remove Gateway password. Take Gateway Windows XP as example, there is a default Administrator account. We can use it to unlock locked account if this built-in account is still blank or accessible.
A. Press Ctrl+Alt+Del twice when PC starts and then input "Administrator" in the username field and leave the password filed blank at the classic login screen. Press Enter and login PC.
B. Start -> Control Panel -> Administrative Tools -> Computer Management -> Local Users and Groups -> folder Users
C. Right click the account user name which password was lost, and then click Set Password -> Reset password -> keep New Password and Confirm Password blank.
D. Right-click locked account and select Reset password.
E. After finished, restart PC and login.
Optional 4: Ophcrack Windows Password Recovery software
Ophcrack is a free Windows password recovery tool which only works for passwords with less than 14 individual characteristics.
A. Download the Ophcrack LiveCD and burn its .iso file to a CD on an accessible PC.
B. Insert the CD into the locked computer and restart it.
C. When computer starts, we have to press the correct key to enter the boot menu.
D. After select the drive that the CD is in at start menu, do as the following instructions.
If we forgot Gateway laptop password and need Gateway password reset, we can easily reset Windows 7, XP, Vista password on Gateway PC or netbook with the above 4 optional methods.
Source: http://windowspasswordrecovery.net/article/gateway-password-reset.html
on May 06, 2011 • Computers & Internet
8helpful
What is the password for a belkin router F9K1123v2
If you are asking what the default credentials are to log into the admin panel of the router, then the options are below.
Default usernames: admin, Admin, [blank]
Default passwords: admin, password, [blank]
If you are asking for the Wi-Fi password, that is unique to the user who initially set it up. You can reset the router but following the manufacturer instructions and holding the reset button down in the back. This will erase all settings on the router.
Bought a laptop at auction but don't have password to open up
Hi
Password for user,
1- if its windows 7 then do two times ctrl +alt+del then enter user:administrator without password
2- if its windiws 10 then see this link
https://youtu.be/P50PQwiYNec
Hope this can help you.
2answers
Forgot admin password cannot how to reset admin password gateway lt2104u
Look on Ebay for a password reset disk. Many vendors on Ebay sell a bootable "linux" disk that you boot from and then you can edit your password file on Windows. I have versions for XP/ Vista.Windows 7.
Be sure to get one that works for your version of windows. You must set the BIOS to boot from the CD drive first for this to work. About $5 to $10 for the reset disk.
Regards,
Dennis
Bio's Password reset for gateway 98 desktop
BIOS passwords can be reset or removed in two ways:
1. using software 2. using hardware.
1. Software removal method - Here are two software apps to reset or retrieve BIOS passwords.
!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore.
You can download it here:
http://www.syschat.com/download120.html&act=down
CmosPwd - Cmos password recovery tools
http://majorgeeks.com/CmosPwd_d239.html
You will need to create a bootable Dos, or Linux or NT cd in order to run them.
2. Hardware Removal method :
- First you need to open the case.
- Then find the cmos battery (It will look like a nickel sized silver disk located on the motherboard).
- Remove the cmos battery for 30 seconds and then put it back in. You may have to tweak the bios settings afterward, but the password will be gone.
Good Luck!
3answers
If you are looking for the Password to an ATT 2 Wire ADSL Gateway it is located on the router. Here is an Image of where it should be located and the password is the second set of numbers between the 2 barcodes.
To get into your ATT 2wire from the computer follow these steps and you can set up your own information manually.
  1. Type this address into your web browser. http://gateway.2wire.net/
  2. You will go to the the main administrator gateway page.
  3. Then click on change system password.
  4. Change it too a password of your likeing.
  5. Save your new password.
  6. You are done.
We have a westell, model 327W and do not have the security code or the one we have does not work. Whar do we do?
Access the setup page through a web browser on a wired computer. In the address bar, type 192.168.1.1.
Default Username: admin
Default Password: password
If this doesn't work, try admin for the username and password. If still doesn't work, then you will need to reset the gateway. Take note that before resetting the gateway, you need to know the internet connection settings. Resetting the gateway will restore the settings to default.
Once you are in the setup page of the gateway, go to Configuration> Wireless> then look for the wireless security. It should show you the WEP key.
Enter the wep key on your laptop.
I hope this works! Good luck!
I hv 2 wire modem bought from my friend, I don't know how to reset user ID and password in this modem
you can try resetting the modem by picking a small pin and pocking in behund the modem which states "reset"
Or if you can access the gateway you can reset it from there.
to access gateway in case type in your browser -- > http://gateway.2wire.net/mdc - <-- you will be prompted to enter password . The default password is 2wire . Once you entered in , scroll down to Troubleshooting which will be on your left
, search for resets <--- Click on it, it will direct you to a page where you can reboot system and stuffs.. Click on the button RESET beside factory defaults. Your modem will be reset to factory default, your power light will change orange and be normal back for about 10 secs ... When everything has come back to normal, you can then continue to enter your user id and password to log in internet.Or alternatively u can Go to http://gateway.2wire.net/setup <--- and configure your modem from there with a step by step guide :)
THANKS
Top 2wire Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
