You can solve the problem by reseting the router
Plese make sure you hard wire the Router to the computer (Using the Ethernet Cable)
Use the following steps to reset the router using this method:
- Open your Web browser and enter the IP address of your router. By default, the address is “192.168.1.1′.
- Enter your user ID And password when prompted. Hopefully this has been changed, but if it hasn’t, the default is no ID and “admin” as the password.
- At the top of the Web page, click “Administration” and then “Factory Defaults”.
- Beside “Restore Factory Defaults”, click “Yes”.
- Now click the “Save Settings” button at the bottom of the Web page.
Your WRT54G wireless router should now be reset to the factory defaults.
If you were trying to uncheck the box for Use Windows to configure my wireless network settings you can change it by disabling the "wireless zero configuration"....i guess you are using Windows XP...if it is Windows Vista...you got to disable "WLAN Auto Config"(Not recommended, as vista works best with defualt windows utility i.e. WLAN AutoConfig)
Go to start...click RUN (Or Simply Press Windows Key and Letter 'R' together on the Keyboard)
Type in services.msc
Scroll through the bottom of the page
Highlight Wireless Zero Configuration and do a right click to select Properties
Go to Properties and click on Startup Type and change it to disable
Click on Apply and click OK
Just a small advice do check for any kind to Electro-Magnetic interference caused by any devices like - Microwave,Cordless phone,Mobile,Fridge, or electronic device as they may interfere and may not let the Router and Computer to connect
Hi here,
I have the same problem, I can not access to 192.168.1.1/2, it happens after I try to upload a new firmware, suddenly did not response. after this I proceed to reset to factory setings, but steel can not access at all.
On the LAN connection icons, appears not answering the EOC"s to my commands(mean to access to programming), I have two units with the same problems and it happen the same way both. PLEASE SOMEBODY TELL ME, WHAT TO DO, It may need to reset the IP address manualy?? tell me how please!, Thanks Jose Luis Ogawa, Baja Mexico.
