Question about Rotel RMB-1095 Power Amplifier
Rotel Amplifier RA-9808X
I have a problem with the TONE on/off selector of which the contacts are badly corodite. I would like to replace the switch but I do not have a circuit diagram could anybody please help.
Vic le Roux South Africa
E-mail vicleroux@telkomsa.net
  • Anonymous Mar 30, 2014
    I Have rotel ra 414 amplifier and i want to know if there is a way to connect to hifi system or pc?
    New Friend:
Allthough 4 years later, If you need a schematic just mail me, I'll send it to you w/o any costs.
Posted on Nov 17, 2011
    Scholar:
  • 146 Answers
Instead of replacing you can try and clean it. There are a lot of good contact cleaners out there.
Posted on Mar 15, 2008
SOURCE:
I cannot get equal volume on both channels. It snaps crackles,
If it's an old type control then you can spray it with Servisol switch cleaner. You might have to take the top cover off to get better access.
May 27, 2013 | Rotel Ra-2030 Integrated Amplifier Review,...
Tip
REPAIR ASSISTANCE
ROTEL RA 980BX
Fault: No output from left channel. The right channel is working fine.
Added some photos and circuit for reference
While testing the amp noticed that the left channel is giving switch on off thump while powering ON and OFF the amplifier. It happens when there is DC voltage flow through the speakers. It shouldn't be there. And the thump is there only on the left channel. While testing the amplifier section found that all the transistors where idling at mentioned voltage. All Base pins where around +/- 0.5volt. and the output is almost 0.012mvdc.
FOR MORE DETAILS CHECK THE LINKS
http://electro-medical.blogspot.in/search/label/ELECTRO%20MED%20SERVICES
on May 17, 2015 | Miscellaneous
Rotel RA 12
I think RA 12 is not existing type, but RA 12xx types exist.
Please try this link, and I hope you will find the relevant documentation.
gylacz
Mar 18, 2013 | Audio Players & Recorders
The two 5 amp fuse inside the amplifier keeps blowing
That must be the inrush current.
Maybe you are using the wrong fuses.
Please check if those are fast or slow types.
You need slow types.
Good luck,
Gerard
Jan 17, 2010 | Audio Players & Recorders
My Rotel RA-931 integrated has an intermittent left channel. It occasionally cuts out or loses most of its volume. The key thing is this: if I crank the volume it'll suddenly come back and be okay for a...
This could be a bad solder joint, or dirt in the volume control. Try spraying the volume control with Servisol Video 40, available from electronic shops such as Maplin, or Radio Shack.
Dec 22, 2009 | NAD C272 Amplifier
I have a problem with my RA-9808X. A guy I know tried connecting some small speakers from a car with it, and he probably did something wrong. Now it doesn't light up when I plug it in and turn it on...
All I can say to you is look around where the mains goes in very carefully. Fuses are sometimes hidden or in a case or cover of some kind. Sometimes amps use fuseable resistors. If the PC board is marked up look for resistors with "RF" or different indication to a normal resistor. Otherwise fuses will have "f" markings on the board. Remember the power supply part might be enclosed in a metal case with holes in it, so might be hard to spot fuses.
Nov 02, 2009 | Rotel RMB-1095 Power Amplifier
Need manual for ra 840bx4 & wattage output when remote speakers?
Lets try the simple stuff first. This whole problem could be caused by a dirty switch contact. Pick up some electronics cleaner from a local electronics shop and spray the switch (from the inside of the unit). Work the switch on/off a number of times then respray one more time. That should clean out any dirt that is there. Try the unit again and hopefully the problem is resolved. If not, then the switch itself may need to be replaced. When you get the cleaner, get one that contains a lubricant as well. This will help to prevent the problem from coming back again.
Dan
Jun 20, 2009 | Rotel Audio Players & Recorders
Right speaker jack not working
Why would it die from being in storage? Oxide or corrosion on contacts, volume potentiometer, Tape Monitor or other switch contacts.
Try manipulating all controls and switches throughout their ranges many times and see what happens.
Check the heaphone jack. If it works so does the right amplifier. While you're at it, insert the headphone jack multiple times to cycle its contacts, too.
May 18, 2009 | Rotel RMB-1095 Power Amplifier
Rotel RA 9808X Amplifier
I'd suspect that one of the two output transistors on that channel has gone bad. If you are unsure how to test or troubleshoot this, then you might try replace both the NPN and PNP outputs and catch the bad one that way. If your amp uses an output module then you would of course have to replace the module which would replace all the output transistors on both channels. Good luck. Another thing to look out for, is the emitter bias resistors. They are the large white ceramic ones near the outputs. Sometimes one of those will open up too. They will be of a very small resistance value like .5 ohms (point five ohms) or something in that general ballpark, and have a wattage value of typicaly 5 watts. So they are pretty big resistors. Be sure to check them all even if you do find a bad output transistor. They will often go out with the transistor. Good luck.
Jan 18, 2007 | Rotel RMB-1095 Power Amplifier
775 people viewed this question
Top Rotel Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
Are you a Rotel Audio Player and Recorder Expert? Answer questions, earn points and help others
