SOURCE: I need a manual for Simplicity Pro Serger SW432
I went to Simplicity's website and downloaded the manual for free. Hope this helps.
SOURCE: Need a set screw for
you could try a generic one from this website and see if it fits?
http://sewing-machine-parts-store.com/list.asp?subcat=Screws
SOURCE: I am looking for where
You can purchase complete sets of Allen wrenches in either SAE (U.S.) or Metric sizes at most hardware stores, home improvement stores, Radio Shack stores, etc. for relatively short money. If you can bring the screw with you or find out what size it is from inside your manual - you might be able to purchase only the particular wrench you need. If you can't find the size of the screw documented in your manual, you'll have to check both SAE and Metric sizes for the best fitting wrench .
Sewing machines often use very small fasteners and are precision devices through and through. Simply using a wrench that "fits" as opposed to the one that is the "correct size" will affect how many times you'll be able to loosen and tighten that screw. Using a wrench that "fits" will eventually wear out the screw head making it impossible to turn in or out, much quicker than using the correct size Allen wrench.
I hope this helps and good luck. Please rate my reply. Thank you.
