Fender hot rod´s have an common problem on the plate resistors of the preamp and phase inverter tubes.
Check if the 100K and 82K resistors on the tube socket board are not brown. Those resistors usually need to be changed to bigger ones 1/2W.
this guy made a good document about this fix:
http://home.comcast.net/~fredholz/Justin-Holton/Fixing%20Loud%20and%20Intermittent%20Crackle%20or%20Static.pdf
Are the output tubes well used? I test them by having the amp on but all volumes down. Flick each one after the amp has been on for some time. If there is any noise, replace them. They have become microphonic.
Poosibly the tube sockets are not holding the tube in place anymore. Usually the Fender's have a spring loaded carriage so to speak that hold tubes in place.
Tubes are known to become microphonic, which could explain what you are hearing. Maybe check out the power tubes, and the rectifier tube, if it has one. A way to check if they are becoming microphonic is to turn the amp on, let it warm up, turn reverb off, have the volume up, and tap on each tube with the topside of your fingernail. If you hear vibrations, sort of a hollow sound....tube is on its way out, if not bad. Good luck, hope this helps.
Thank you for your reply. More details:The amp is only a year old. The preamp tubes have the rubber stabilizer around them. I replaced the preamp tubes and tightened chassis attach screws to cab but still have the rattle which sounds like a filament vibrating when playing guitar "C" note.
