I would try VGA to VGA hook up first to narrow down the problem before start taking the monitor apart.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). See example of failed monitors to get some ideas of what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
According to the spec, the Xerox has both DVI and VGA input, unless I am wrong per: http://reviews.cnet.com/lcd-monitors/xer...
The native resolution should be set to 1280 x 1024 @60Hz.
my CRT monitor works perfectly on same computer. i don't have any other lcd monitor atm and i don't have a graphic card with dvi-i connector to test my Xerox XG-91D. that's the reason for using that adaptor
