Sony FD Trinitron WEGA KV-27FV17 27" TV Logo
Anonymous Posted on Apr 01, 2010
Sony Trinitron TV
My Sony Trinitron KV-27FV17 TV cilcks on and immediately shuts off. The red light blinks twice, pauses and blinks twice, etc...
Christopher Stearns
Level 2:
  • Expert 101 Answers
  • Posted on May 30, 2010
Christopher Stearns
Expert
Level 2:
Answers
101
Questions
0
Helped
41331
Points
217
Read the answer on this page really helpfull
http://en.allexperts.com/q/TV-VCR-Stereo-1749/Sony-Trinitron-KV-32V42.htm
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 31, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1920
Points
My tv had a problem similar to this but blinked 6 times i have used a hair dryer to heat the board up for about two minutes and usually it turns on not always but i hope this helps
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Apr 01, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
0
Helped
2047
Points
12
You should take it back and get your $ back
My sony trinitron kV ES 34M90 GIVES 6 ERROR BLINK CODES
Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. To get more details, http://electronicshelponline.blogspot.com/
1helpful
Sony TV turns off immediately after turning on
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits. Check this link to get more details about Sony Blinking codes.
Turn on tv no picture no sound standby light starts green changes to flashing red
the number of red light flashes indicate where the fault lies...sony error codes are easy enough to find if you google the model with the number of flashes.hope this helps somewhat as you dont say how many blinks!!
regards,steve.
ps.line output transformer failure rates are quite high on these sets,usually resulting in two red blinks-pause-two red blinks-pause etc...
My sony wega blinks the standby light red 6 times, pauses and repeats. Cant get a picture on it at all. Any ideas?
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • 0helpful
    Sony wega trinitron(1999) KV-36FV15 Moved tv now audio no video
    Seven blinks, pause, seven blinks, etc. means "Horizontal deflection stopped" and indicates a serious problem, probably on the D or DZ board (whichever is applicable).
    If this is the case, the TV will have to be serviced by a professional.
    I hope this helps :)
    Best Regards,
    James
    Sony Wega
    Please count light flashing again. Light flash time is "0.3 Sec" and there would be pause (light Off time) for "3 Sec". Start counting after pause to next pause.
    SONY KV-27FS20 TV does not start
    Only 3 things bad Flyback transfomer,bad picture tube ,shorted hori output transistor. more then likely you have a bad picture tube,ive already throwed over 20 sets out due to bad tubes.
    NOTHING HAPPENS!!!!!
    power supply probel, need to take to service
    2answers
    Sony trinitron kv-27fv17
    TWO Blinks---B+ over current protection (OCP) , unit goes to the standby, this means there is a component inside your TV set, in the main power supply or the sweep power supply that is not letting the TV set's power supply regulate properly. I'm sorry to say, there is no quick fix for this and is going to need to be diagnoised by a trained tech. Good Luck
    Top Sony Televison & Video Experts
    Grand Canyon Tech
    Grand Canyon Tech
    ZJ Limited
    ZJ Limited
    matt martin
    matt martin
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
