Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
Posted on Apr 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My akaki plasm has a one inch vertical line down the center of the screen
Anonymous
Level 3:
President:
  • Master 1,077 Answers
  • Posted on Apr 01, 2010
Anonymous
Master
Level 3:
President:
Answers
1077
Questions
Helped
774532
Points
4687
Most likely one of the scan/buffer boards needs to be replaced to fix the problem. The vertical scan/buffer boards will be on the top or bottom of the plasma panel. It's basically the last boards that is connected to the screen panel itself.
You maybe lucky and its only a loose connection. Replacement boards can be found at a good price a E-bay. Just make sure the part numbers match up on the circuit boards.
1helpful
Why my t.v screen is one inch less from down side?
Vertical scan output section circuit fault.
Visit this site to get more details.
How to fix green vertical line on 60" vizio led smart tv
I had a similiar problem on a Sony , vertical line or lines on the left side of the screen. It was the driver board for the LCD. Good Luck
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
3helpful
How do you adjust headlights on a 1993 chevy C1500
if you look at the light, there is an adjustment screw at the top of the light that controls the up and down motion , clockwise will raise the beam, and a screw on the side that controls the side to side motion. the best way to center your lights would be to park the vehicle 25 feet away from a verticle wall. be sure to be very square to the wall and on level ground. make a tape line vertically on the wall in very close relation to the center of the vehicle, and another tape line vertically in very close relation to the center of each headlight. now place a tape line horizontally in very close relation to the center of the headlights. start with low beam adjustment. adjust the high intensity zone to 2 inches below the horizontal line and 2 inches to the inside of the vertical line directly in front of the headlight. for high beam adjustment, adjust so that the high intensity zone is centered on the center vertical line and just below the horizontal line. hope this helps
Trying to adjust head lamp in a 1995 chevy C1500 just had to buy a new lamp assembly
4helpful
2answers
BLACK LINE
same problem 2 inch vertical line in center of screen! could this be something loose in the back??
2answers
Vertical line in centre of my zenith plasma p60w26 tv
I also have this problem, but with 2 black vertical lines on the right side of screen half way through. Lines disappear from time to time but reappear. Is there anything I can do to get rid of them. Help me out please
.... Thank You.
Vertical Line in center of screen
never heard of so called card myself but ,is the line your talking about from top to bottom or from side to side in the middle?straight across middle is called horizional which means vertical problem so you have either bad capacitors 35uf 100v ,1uf 50v, or bad vertical output ic.
2answers
Vertical Line of Blue Down 1/2 an inch from center screen
Usualy a problem with the LCD screen itself, that takes replacing the whole screen to fix. Sorry. Did you know that it had a problem when you bought it? Could also be an internal connector that has gone bad. There are tiny transistors on most displays that control whole rows and columns. It sounds like one went bad, causing a dead, or constant on, column. Unless you are REALLY handy, it will probably need to go to a service center for repair, which could be more expensive then what you paid for the player. Good luck
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
