We just got a new computer with Windows 7. We have Print Shop projects that we would like to keep (we have projects from both Print Shop 23 and version 5). The Print Shop 23 projects are coming up fine, however, the version 5 ones are not. Is there any way to keep them?
You could try installing the version 5 on your pc. There could be a compatability issue so follow the information below if it will not install.
The Windows® Vista Program Compatibility Wizard can allow older programs that were not designed for use with Windows® Vista to run on Windows® Vista.
The Program Compatibility Wizard prompts you to test the program in different modes (environments) and with various settings. For example, if the program was originally designed to run on Windows® XP, set the compatibility mode to Windows® XP and try running the program again. If successful, the program will start in that mode each time. The wizard also allows the use of different settings, such as switching the display to 256 colors and the screen resolution to 640 x 480 pixels.
To run the Program Compatibility Wizard, complete the steps below:
NOTE: If you have questions regarding the Program Compatibility Wizard or Windows® Vista (or both), contact Microsoft®, or go to http://www.microsoft.com for additional information.
NOTE: These display settings are not available options in Windows® Vista. They are only available when running a program in Program Compatibility Mode. The only reason to choose either of these settings is if you are experiencing difficulty installing or running an older application designed to run in Windows® 95, Windows® ME or Windows® 98. If all options remain unchecked, then the current Colors and Screen Resolution settings will not be altered.
By default, Windows® Vista uses visual themes that may change the appearance or behavior of other programs, especially those games or educational programs that include intensive graphics and animation. To prevent the visual themes from affecting these programs, check Disable Visual Themes.
NOTE: If the settings are not correct, click the Back button to return to the previous screen (or screens) and make the necessary changes.
NOTE: After the program is closed, a window with the question "Did the program work correctly?" will appear. The "Yes. Set this program to always use these compatibility settings" will be selected.
NOTE: If the program did not function correctly, click "No, try different compatibility settings" and complete the Wizard. After completing the wizard, try the program again.
Windows 7 was fundamentally expected to be an incremental move up to the operating system intending to address Assignment Help Online Windows Vista's poor basic gathering while at the same time keeping up hardware and software similarity.
