It is very simple actually. What you will need is a face plate, an aftermarket wire harness and the skills to connect this wire harness to the new CD player harness, they are usually color coded so very simple. TO remove you stock CD player you will need to pry off the plastic surround then there are 4, 7mm bolts that will need to be taken out and the stock CD player will pull out. Unclip the wire harness and antenna
