Tried to upgrade my firmware on the zen touch to be able to use it with Vista. Upgrade on XP and with media player 10 as Creative say. However player now only in recovery mode PC does not recognise player, cannot get any firmware to player shows version 0.0.10 on player screen. Any help appreciated
firmware problem
Before preceding, goto control panel, add/remove programs (vista equivalent) select windows media player and uninstall note the response it gives you. If it is going to allow you to uninstall OR downgrade windows media player to version 9 then keep going. If not, then find another computer that you've never used the player on try upgrading firmware there, make SURE it's got windows media player 9 by downgrading it in add/remove programs.
Now for the fun stuff:
Sounds like the same problem I've resolved several times in the past on here.
1. Plug in the device.
2. Goto device manager in control panel and remove the device drivers.
3. Reboot if it asks you to, make sure to unplug the device.
4. Goto device manager again, remove the USB hubs.
5. Don't reboot.
6. Goto control panel, add remove software or equivalent for windows vista ultimate.
7. Select creative labs, and uninstall any and every zen related software.
8. Don't reboot.
9. Goto my computer, find the creative directory located on your main hard drive at \program files\creative. Deleted it completely.
10. Select windows media player select uninstall, or downgrade accordingly.
11. Make sure your zen touch is not plugged in and reboot your system.
12. After system loads, plug in the device and run the firmware software again.
And if you wish, reinstall windows media player 10 and the creative software (which you don't need at all with vista) all the other drivers should reinstall themselves.
BTW it's a hell of alot easier to just use another CPU if you have access to one, I've done it both ways and it saves alot of time.
I dont know if it's windows media player 10 or 9 that it needs to be downgraded to. Just downgrade it if it allows you too. I have 11 and I downgraded it to 10 and it worked.
So it should work by downgrading WMP11 to 10.
Just wondering if I solved anyones problem?
Excellent thanks for responding
Problem solved: this is what i did, on my existing pc i have a fully updated xp with sp2, no creative software installed, i upgraded wmp9 to wmp10, reboot the machine, connected my zen, it appeared in the device manager. in the devicemanager i went to the properties of the zen and had the drivers updated, then i started ZenTouch_PCFW_L4_1_01_03,exe, got the message that i should connect my zen, closed, started ZenTouchP4S_PCFW_LB_2_11_01.exe and bingo!! the message appeared that i already had this firmware installed, according to my zen (stuck in recovery) i had firmware 0.0.10, updated the firmware anyway and it worked, no need to throw my zen in the wastebin.
Can I ask a couple more questions please.
I'm running XP SP2. I have a Zen Touch, model DAP-HD0014. Firmware version is 1.01.03. Application software I have installed on the laptop is 3.20.21 (I also have the .exe for 5.10.38 which I uninstalled 'cos this didn't recognise the device).
So, my questions are:
1. Do I need to upgrade the firmware on the Zen Touch ?
2. Ditto for the driver on the machine ?
3. Ditto for the application itself ?
BTW- I have upgraded to WMP v10 as an aside
Please help! Am getting very srustrated at this stage
Cheers
C
SOURCE: creative zen
After three months of trying and trying in many computers, following many, many procedures found all over the Internet, my Creative Nomad has accepted the firmware and has borned again.
What I did?
1. Connected the Nomad on a computer with Windows XP and Windows Media Player 9, that never has been touched by a creaive device.
It recognizes the device but can´t find any update to the drivers,
2. Updated Windows Media Player 9 to Windows Media Player 10,
3. Restart the computer
4. Connect the Nomad and the computer recognizes the device and autamtically search and found updated MPT drivers.
5. Run the firmware update program "ZenXtraP4SAudible_PCFW_LB_2_10_03 (Creative Zen Xtra PlaysForSure Firmware 2.10.03)"
6. Finally the magic button always has been disabled was enabled so start reloading firmware.
And now the Nomad is working in windows vista.
The difference between the computer where the firmware works and the others is that this has never had media player 10 or 11 and never has installed creative drivers.
Hope this can be useful to smoeone, somewhere, sometime.....
SOURCE: Creative Zen Touch firmware problem
I had the same issue after trying to update firmware the PC kept saying the player was not connected, I have copied the reply below from Creative Customer Services on how I fixed this problem. I was lucky that I have access to an old PC that had WMP 10 so I didn't need to mess with my own PC. However, there was some messing about with the instructions to get the fix. My main tip is follow the instructions below, then go to device manager and uninstall the Zen from your USB list, it will probably be flagged with a yellow triangle. Remove it totally and then reinstall the Zen driver, this worked for me after I had taken the steps listed here;
1. Please uninstall all Creative software & Drivers.
2. If WMP 11 is installed, remove it including Media Player 11 runtime
(may require a reboot for each thing).
Go to add/remove programs and uninstall these two files (this will put
your pc back to wmp10). http://support.creative.com/kb/ShowArticle.aspx?sid=16737
Related topic is further explained on this page http://www.microsoft.com/windows/windowsmedia/player/11/readme.aspx#DevicenotrecognizedafterinstallingWindowsMediaPlay
3. Download the following files from the website and save them to a
unique folder.
http://support.creative.com/welcome.aspx
You may have to select your own Product > Choose your Specific Model>
then Double Click.
Down below; please ensure that your Operating System selected is Windows XP.
Driver : Creative Zen and Jukebox Driver Upgrade version 1.30.03
Firmware: Creative Zen Touch PlaysForSure Firmware 2.11.01
You may want to click the Show Details button on the right side for
additional information.
4. Re-install the Zen Driver and reboot the PC and then connect the
player.
5. Make sure the firmware update is ready,
Run the program but don't click the language bit yet), leave the mouse
hovering over your language selection.
6. On the Zen - select the option "reload OS"
7. As soon as it flashes up "reload new firmware now via USB" click the
language button on the firmware.
8. Now PC should find it and allow you to re-load the firmware. (it may
take a few attempts)
9. Once complete, click close and restart the pc. Everything should now
be fine.
10. If installation is successful, you can re-install your WMP11 and
everything should be okay this time.
Good luck
SOURCE: Firmware Update problem.(Failed)
hi i have Creative Zen 4GB Mp3 player.
When i plug it via USB on my PC i can't upgrade frimware.İt always run in recovery mode.i start firmware upgrade and installer says "firmware upgrade failed.".Media explorer says Storage Media is 50 mb.Please help i don't know anything to repair it...
Same thing here, player is recognized by windows device manager, tried to reload firmware but then the application asks me to connect my device, can't find any solution at creative's
I have the same problem. I formatted the disk and I tried to install a new firmware, but my computer doesn't recognize the player
I've got the same problem. One day I acidently put my Touch itno to a bag turned on an forgot to use the hold button. Next thing I know it says firmware problem an it thinks it's only 20.00mb big. it wont sinc with media player or nomade. I have tried reloading the firware from creatives' site and it won't work because nomade can't find it it's so ircsome!!
Same problem, The Creative site says they do not support Vista, great. In explorer, it shows the Zen but has an "X" saying "not connected". I'll just wait a while, maybe a fix with show up
Zen Creative MP3 Player - Frozen in the Recvery Mode and when I turn it on, it always says Ceative Filmware Problem and I cannot reboot or anything. It's just FROZEN!!!
The computer wont detect my device. I am using Windows Media Player.
i have the same problem as u guys:( how to fix it???
I'm having trouble updating my zen touch for some weird reason it say's I got only 20.00 mb and the firmware is only v0.0.10 I want to update it to v2.11.01, when I turn it on it says "firmware problem". My pc can detect it but not the firmware program, it says my player is not connected, so i connected it but nothing happens, I was wondering is this problem fixable or I'm screw. Thanks in advance.
this is an absolute headache, did everything creative said. got mu hands on a xp cpmputer, downgraded to sp2 & downgraded wmp to v10. Then when I tried to install the firmware, my player get's stuck in recovery mode. Read the solutions below but can't find the device manager on the old xp pc I have. thinking of throwing my touch away.
Hello, i'm Boris. I in possession of a 40 gigabyte Zen Touch that has a problem. Each time i connect the device to my PC, i am told that it malfunctioned and windows cannot recognise it. i had lost the CD package that came with it but i have downloaded all the software necessary for it to be used. I have upgrades of the firmware. The problem seems to be that the firmware was destroyed by my siblings.
How do i get the original firmware version ie version 1.01.03 installed so that i can use it on my PC?
Same Exact Problem
my mp3 player zen has a firmware problem and so i went to the website in recovery mode and firmware update but it says connect the device even tho its connected
tried to upgrade dvd firmware and it failed no player is dead
tried to update firmware on a dvp5990/37 dvd player and it failed now dvd player is dead
