Hey,
iv opended up my makita drill to clean it and the covers wont seem to go back together. can you please send me a diagram so i can see if any parts inside it have being put in wrong.
Makita 18v cordless LXT drill driver 18 v BDF452
thanks
SOURCE: chuck change
open the chuck fully and remove the scre inside by turning clockwise. insert allen short side in to the chuck & tighten
the chuck. hold the drill & hit the allen counter clockwise & do it again as needed.
SOURCE: how do i re-assemble a makita 18v cordless drill
I HAVE A MAKITA 18V BHP451 AN THE SPINNING BARREL AT THE BACK OF DRILL KEEPS BURNING UP, HAVE REPLACED ITEM WHICH STILL SEEMS TO BE DOING IT
SOURCE: my chuck is broke , on my 18v makita cordless
Put the chuck key on and strike it with a hammer counter clockwise. the chuck key must be properly seated in the hole. Once the chuck is brokrn free, you can unscrew it my hand. Buy a new chuck an screw it in olace and againm strike the key but no as hard clockwise. It will self tighten more as it is used, Good Luck-Ned-
The large black part of the chuck should turn left and right to extend (close) and retract (open) the three chuck teeth that hold the bit in place. Turn the chuck to open it far enough to get your bit fully in the chuck then turn it closed to hold the bit in. When the teeth make contact turn the chuck a bit further to get it tight enough that the bit won't slip. When you get used to it, sometimes it's easier to hold the chuck lightly and turn it by lightly squeezing the trigger to turn the chuck with the drill motor.
Already fixed? Otherwise google - www.kruis.nl on top choose onderdelen. Then left choose Makita. After that put in centertop your machine type. Then you will see schematic and partlist
