My Wireless Lan adapter is not working.
I tried another WL LAN (Atheros) . It work properly but stop working after a system restart.
Make sure that the built-in wireless lan is disabled. If your pc is XP or vista, uninstall the new WIRELESS LAN(go to control panet, add/remove programs), select the Atheros Software. Leave the WIRELESS ADAPTER connected to your pc. Insert the disc, do not run the set up. RESTART THE PC. The drivers for the WIRELESS ADAPTER should install, if not load drivers manually.
MAKE SURE WIRELESS ZERO CONFIGURATION for XP is running. You should be able to detect wireless networks.
I want acer aspire 3690 wireless network adapter
Thank you 2Gigs
I tried the procedure but I don't know how to make WIRELESS ZERO CONFIGURATION for XP run.
still the Ethernet controller in the device manager show the yellow sign and the wireless adapter unrecognized.
UPDATE
The problem solved by re install of another version of atheros driver.
Thank you all
Wireless connection stopped working for some reason...been working fine for a long time
