Question about Dell 1700 Laser Printer
Toner is printing on right hand side of each page printed
It seems like a roller problem because the toner is only printing in 4 places down the right hand side of the page.
I changed the toner cartridge and the same thing happened.
Is it the drum?
  • 1,110 Answers
Most likely it is the drum cartridge. The other causes such as toner on the laser optics would not produce an on again off again print area. It would be blank the entire way down the page. Since the toner prints in patches down the right side it means it is coming from something that is "rotating" and that narrows it down to the drum.
Good Luck and Thank You for using Fixya.
Posted on Apr 01, 2010
SOURCE:
When i print an invoice for my business my invoice is printed with a streak down the right side of it. everything else on the invoice is printed with great quality but the streak down the side looks like...
Remove the toner/drum cartridge. If you can look up into the area above the toner cartridge with a flashlight, look for either dust on the laser glass or some other obstruction. Also check the transfer roller that lies just below the drum. Make sure that's clean with no damage to its sponge surface. DO NOT TOUCH IT WITH BARE HANDS!!! The oil from you skin will damage it. Most important thing to check: Look straight back to the rear of the printer without the cartridge in place. You should see an orange or red roller towards the back. That's the pressure roller for the fuser. Look with the flash light at the grey or light brown roller adjacent to that pressure roller. You said the right side is faded. Look at that right side of that roller. If there is any damage or foreign debris stuck on that side, and you can't clean it with cotton swabs and 91% Isopropol Alcohol, you probably will have to replace that fuser.
Oct 24, 2013 | Brother HL 1440 Laser Printer
KYOCERA FS2000D ecosys laser printer. I replaced the toner as per instructions. First print had a vertical line down right margin of page. So googled if I should be cleaning anything because it does not...
its probably on the developer roller look at it as you spin the roller you should see a darker than normal area wipe the roller with a dry cloth until you no longer see it if you are turning it the right way no toner will come out the roller will have a thin even coating of toner on it or try cleaning the charge roller on top of the drum unit it should be 1 of the 2 these machines need to have the oem toner
Mar 16, 2017 | Kyocera FS-2000D Laser Printer
I have a Lexmark E250DN printer. The photoconductor kit was full of excess toner. It was easy enough to unscrew the holding tank and to clean out the old toner. Everything seems to work fine now except for...
Probably you need to purchase new one - Lexmark E250X22G photoconductor. Every 60000 prints you need to change it or
If it is OPC drum (green roller) damaged.
May 29, 2017 | Lexmark E250dn Laser Printer
How do i clean the rollers
Introduction Your printer requires minimum routine maintenance. This chapter explains the following tasks
  • Cleaning the printer
  • The toner cartridge
  • Extending toner cartridge life
  • Clearing a TONER LOW message
  • Replacing printer parts
Cleaning the printer To maintain print quality, thoroughly clean your printer:
  • Every time you change the toner cartridge
  • After printing approximately 6,000 pages
  • Whenever print quality problems occur
Clean the outside of the printer with a lightly water-dampened cloth. Clean the inside with only a dry,lint-free cloth. Observe the warnings and cautions that follow the cleaning tasks on the following pages. Caution To avoid permanent damage to the toner cartridge, do not use ammonia-based cleaners on or around your printer.
Printer Cleaning Tasks Before you begin these steps, turn the printer OFF and unplug the power cord. Caution Do not touch the transfer roller (black sponge-rubber roller) with your fingers. Skin oils on the roller can cause print quality problems.
If toner gets on your clothes, wipe it off with a dry cloth and wash your clothes in cold water. Hot water sets toner into fabric.
Warning Avoid touching the adjacent fusing area. It may be HOT
  1. OPen the printer's top cover and remove the toner cartridge
  2. with a dry lint-free cloth, wipe any residue off the Paper Access Cover (it has a green handle) and the adjacent silver metal strip.
  3. Wipe any dust or dirt off the black plastic Paper Feed Guide with a dry, lint-free cloth.
The Toner Cartridge see the printed book pending update of this page Extending Toner Cartridge Life see the printed book pending update of this page Clearing the TONER LOW Message see the printed book pending update of this page User-Replaceable Parts Some worn parts can be replaced by the owner. See Chapter 8, "Solving Printer Problems", for descriptions of the difficulties that can indicate when to replace a part. Warning Switch OFF and unplug the printer before replacing parts. Failure to do so may result in personal injury or damage to the printer. After switching the printer OFF and unplugging the power cord, allow the printer to cool for 30 minutes before replacing the parts.
Unless specifically noted, replacement is the reverse of removal. Always carefully observe the position and alignment of the part you are removing; this is your best guide to replacement. User Replaceable Parts Part Name Part Number Remarks Multi-Purpose (MP) Tray Pickup Roller RB1-2127-000CN Replace both the MP Tray Pickup Roller and the MP Separation Pad at the same time. Multi-Purpose (MP) Tray Separation Pad RF5-0343-000CN Replace both the MP Tray Pickup Roller and the MP Separation Pad at the same time. Paper Cassette Pickup Roller RB1-2204-000CN See Chapter 8 for replacement conditions. Transfer Roller RF5-0349-000CN See Chapter 8 for replacement conditions. Fusing Assembly RG5-0880-000CN 220-240 Volts Cleaning Brush RB1-2260-000CN n/a Optional LC Pickup Roller RB1-2650-000CN See Chapter 8 for replacement conditions. Ordering Information User replaceable parts are available from the authorized HP dealer or from Hewlett-Packard. To order parts, see this information Multi-Purpose (MP) Tray Paper Pickup Roller and Separation Pad Before you begin these steps, turn the printer OFF and unplug th power cord.
  1. Open the Multi-Purpose (MP) Tray.
  2. Grasp the black plastic Envelope Feed Access Cover as shown, and pull it downward and toward you to remove it.
  3. Read all of this step before proceeding. Remove the pickup roller by pushing down on the plastic retaining clip with your right index finger (see inset A) while sliding the roller to the right with your left index finger. When the roller is partway to th right, push in on the small plastic tab (see inset B) behind the right end of the roller and fully remove it.
  4. Insert a flat-blade screwdriver into th indentation at the front of the separation pad and twist the screwdriver blade gently to loosen the pad see (inset). When loose, gently lift pad from its seat.
  5. To install a new separation pad, place it over the opening and press it down firmly with your forefinger to seat it. Be sure the metal edge is toward the front of the printer. To install a new Multi-Purpose (MP) Tray Paper Pickup Roller, slide it over the shaft, then rotate it so that the flat side of the new roller is aligned with the flat side of the shaft. Then slide th roller to the left until it clicks into place.
  6. Reinstall the black plastic Envelope Feeder Access Cover and discard the used roller and pad.
Paper Cassette Pickup Roller Before you begin these steps, turn the printer OFF and unplug th power cord.
  1. Remove the toner cartridge.
  2. Remove the Paper Cassette.
  3. place the printer on its left side so that the bottom of the printer is easily accessible.
  4. Remove the pickup roller by pinching the release clip and sliding the roller off the shaft (the new roller will be installed in the reverse order). Slip the new roller over the shaft and rotate it until properly aligned. Slide the roller along the shaft until it clicks into place.
  5. Place the printer upright, then place the toner cartridge, Paper Cassette, and power cord. Switch the printer ON.
Transfer Roller see the printed book pending update of this page Fusing Assembly see the printed book pending update of this page Lower Cassette Pickup Roller Not applicable to HP printers at ING
Please rate my solution! :)) Thanks for asking me :)
Apr 13, 2011 | HP LaserJet 4 Printer
Even after changing new cartridge my print out has black ink stain on page left and right
This is usually due to a dirty imaging drum roller (green roller below toner). Remove the toner / drum assembly, then separate the two. Now slowly rotate the imaging drum roller by hand using the gear on the side of the cartridge (Try not to not touch the drum roller with your hand, as oils from your skin may cause further problems + toner is nasty) Look for toner splotches to the left and right on the drum roller as you turn it. If you see any you can clean them off with a damp paper towel. Then reassemble the printer and hold the continue button down until you hear the printer start then release it; this will print a test page.. Hopefully that will take care of the issue. Also while you got the assembly out of the printer you can clean the glass print-head lens using a clean, dry, and lint free cloth. The print head lense is located within the recessed area in the top of the printer.
- I have seen that happen to a bunch of those printers and that is usually all it is. Let me know if that takes care of it.
Picture of Drum + Print Head lense for a (1720 / 1720DN).
Link to Dell manual about drum & print head.
(Full link below)
(http://www.support.dell.com/support/edocs/systems/prn1720/en/1720_en/en/d0e4183.html#replacing-the-imaging-drum)
May 03, 2010 | Dell 1720dn Laser Printer
Thick black lines (of toner down each side of printed page
There are problem in your toner, in toner there is a drum which are scratched, you have to replace this drum.
Problem will be resolve.
Regards
Ashly
Feb 02, 2010 | Samsung SCX-4100 All-In-One Laser Printer
My CLP-350 Samsung printer only prints black ink on half the page! While the other colours all print perfectly, the black ink prints strong and clear on the right side of the page but as you approach the...
Here is my solution, hope it will solve your problem.
From your post, I believe your CLP-350N printer has enough black toner. The black cartridge is on the far right side of the printer, so the black toner is harder to go to left side of the roller than right side. Everytime we start the printer, it will move some toner of each color to the roller before it shows ready to print.
Because we always use B&W printing when we start the printer, but less Color printing. The result is there are always enough toner on the 3 color rollers, but the black toner is lean on the black roller. When this gets worse, the left side of the black roller may hardly get any toner at all -- so it only print black on the right side fo paper.
Step by step solution
(CAUTION: Never loss balance while tilting printer! You may drop and damage your printer! Hold the printer firmly all the time! Ask someone to help you if needed!)
Here, front of the printer is where you can access the cartridge, back of the printer is where you connect the power cord and USB cable, left is your left, right is your right.
1.Lift the front to keep the printer tilt to its back at about 45 degree
2.Power on printer while it's tilted back, wait untill green light is on
3.Open the front door, red light will be on, then close the door, printer will start up again,wait untill green light is on
4.Repeat step 3 once again, then put the printer back to level position
5.Lift the right to keep the printer tilt to its left at about 45 degree
6.Open the front door, red light will be on, then close the door, printer will start up again, wait untill green light is on
7.Repeat step 6 once again, then put the printer back to level position
8.Print some test page to see if there is any improvement of black print quality.(Hold the printer button for 3-5 seconds, it will print the test page.)
You may try several times and print several pages each time before you finally cure the problem.
Good luck! And do it safely!
Jan 09, 2010 | Samsung CLP-350N Laser Printer
When printing, I see a vertical streak on the printed page, from top to bottom, about 2 1/4 inches from the left side of the paper, and about 1/16 of an inch wide. I can't seem to see what causes this. The...
This is more than likely down to the upper roller in the fuser assembly. It's the heat roller at the back of the printer. The upper roller wears so paper dust and toner stick to the roller which then can get deposited back on to the page.
Oct 15, 2009 | HP LaserJet 1020 Printer
Striped line down right hand side of printout
all parts are ok just clean the printer it will work
Dec 02, 2008 | Samsung CLP 300 Laser Printer
Printer prints a line across the paper around three inch from the left hand side of the page.
Check your Toner Carts.
Is the line a certain color?
Black perhaps?
Lift the door of the toner cart.
If you see a streak on your toner drum, you will see a streak on your paperwork.
Look at your fuser as well.
Is there a problem with the big orange roller?
BEWARE! Don't touch the fuser roller its EXTREMELY HOT!
Let the printer cool down before inspecting.
Apr 24, 2008 | HP LaserJet 5500dtn Color Printer
Dell 1700 Laser Printer Logo
184 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
