My problem has been going on for quite awhile now but is getting much worse lately. essentially i'll be using my wireless and it keeps shutting down. i unplug it and plug it back in and that will help bring it back up but lately it's going down every 5 to 10 minuets sometimes less. can you help?
fuel and air mix is wrong, carb might need cleaning. or you have a blocked fuel filter. you could even have a air leak in one of the intake gaskets. try some fuel cleaner in the tank and run it round for awhile it may clear it but failing that you will need to check the intake and fuel filter. also check spark plug for its gap and colour. wet is flooded too much fuel
Sounds like your laptop might be overheating. Does it reboot successfully immediately after is shuts down after 5 minutes or does it have to sit awhile before it reboots successfully?
If you can't boot it right back up after it shuts down, then it is definitely running hot and will only boot back up successfully after it sits awhile to cool off.
Things that cause it to run hot: 1) Dust... Dust clogged in the vents, fans and around the cpu and heat sink. 2) A Fan is not working 3) The Thermal Paste around the CPU and Heat Sink has dried up or is too thin to keep the unit cool.
For the best results you'll have to take the laptop apart to remedy the situation especially if you need to get to the Fan, CPU or Heat Sink.
You can try a can of compressed air and blow out the vents and fan area, that might work for a while but you'll be blowing the dust in. It's best to take it apart and blow the dust out.
I am having a look if there was a recall. I have been getting a strong fuel odor lately and saw today that the filler neck and both vent tubes are totally rotted. Quite a hazard, smells just as bad if not worse than a drip leak. I ll let you know within a few days.
Go to control panel and check your power settings. it is possible that it is set to some sort of power save mode. Try changing those settings especially if you see something related to the wireless card. It may have settings to increase the time before it shuts off or even to set it to never shut off.
contact lg at 800-423-000. they may cover the repair. They might charge you a small trip fee and cover the part. sounds like the pwr supply is shutting down.
First you must sure that your wireless card is working Second confirm your wireless setup is right. Then reset your wireless account. Or your laptop battery cant supply the power to your wireless card, check the metal connection.
