Question about Brand Remote Start/keyless/car Alarm Very Sleek
How do i wire in a alarm on my 97 suburban K1500 i need a wiring diagram to find wire colors for windows lights and etc........
  • 1,305 Answers
1997 Chevrolet Suburban Car Alarm Wiring Instructions
Battery Constant 12v+ Positive Wire (+): Red
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Purple or Yellow
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Pink
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Pink/White Or White (This wire must be connected as ignition #2 for remote starting.)
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Orange
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Brown
Parking Light Positive Wire Location: At Headlight Switch Or In Drivers Kick Panel
Power Door Lock Negative Wire (-): Light Blue (Type A)
Power Door Lock Negative Wire Location: In Either Door Harness
Power Door Unlock Negative Wire (-): White (Type A)
Power Door Unlock Negative Wire Location: In Either Door Harness
Door Trigger Negative Wire (-): Purple
Door Trigger Negative Wire Location: At Headlight Switch
Domelight Supervision Wire: White (-), Requires Relay
Domelight Supervision Wire Location: At Headlight Switch
Trunk Release Negative Wire (-): Black (+) Or Black/White (Requires Relay)
Trunk Release Negative Wire Location: At Hatch Release Switch Or Low In Drivers Kick Panel
Horn Negative Wire (-): Black
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): White
Tachometer Wire Negative Wire Location: At ECM. The ECM (electronic control module) is located on the driver side inner fender.
Wait To Start Wire: When hooking up a remote starter on a diesel, you will need to program in the 5, 10 or 15 second wait to start timer in the installation manual. On some vehicles the wait to start light on the dash is not a true (+) positive or (-) negative and the wire from the remote starter will not work.
Wait To Start Location:
Brake Light Positive Wire (+): White
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): N/A
Factory Alarm Disarm Wire Location: N/A
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
Posted on May 30, 2010
6ya staff
SOURCE:
Have1999 suburban k1500 5.7. have spark out of coil but no spark at plugs. have changed rotor and cap several times what else could it be.need wiring diagram to see where wire out of distributor goes...
If you can tell me what color the wire is I should be able to tell you where it goes.
But if you are getting spark from the coil tower the primary ignition system is working.
Have you checked the coil wire, and will it fire a plug ? The coil could be weak enough to fire a plug in open air but not in a cylinder under compression.
You do know for a fact the distributor rotor is turning, right ?
Jan 31, 2014 | 1999 Chevrolet Suburban
97 chevy suburban k1500 brake lights work when barely touched then go off when pressed harder
Check your Brake Switch on the Back of your Brake Pedal, you have loose wires or your switch is not working properly
Apr 09, 2013 | 1997 Chevrolet K1500
Ignition wiring diagram for 97 chevy suburban
Do you need just colors, or actual pin locations?
Apr 01, 2011 | Chevrolet Suburban 1500 Cars & Trucks
Trying to convert a 1990 Chevy k1500 instrument cluster to a 1994 suburban instrument cluster. whats the wiring diagram. of both?. some of the wires are different colors....
did you get an answer to this question?
Basically you need the DRAC out of the donor vehicle. It is located behind the glove box. 3"x3" square box. Depending on axle gear ratios and tire size you may need to change the jumper settings to allow your speedometer to read properly. This is a very simple procedure.
To convert any 88 and later to the 94 dash you will need not only the drac but get it's harness with at least 6" of its wiring as well.
You will need the 94 dash plug also with at least 6" of wiring on it too.
Jan 24, 2010 | 1990 Chevrolet K1500
Just need a diagram showing how to install the
If you need step by step instructions to wire something, you shouldn't really attempt to install a security system, as it will tie into almost every important electrical system in the car i.e. starter, door locks, lights, etc.
However, if you know how to get the lower portion of the drivers side dashboard off, and how to cut/splice a wire correctly and aren't color blind, you should be able to follow the installation instructions that came with the system. The wiring diagram for your car is:
What/ Color/ Where:
Constant 12V+ White Ignition Switch Harness
Starter Black/White Ignition Switch Harness
Ignition Black/Yellow Ignition Switch Harness
Accessory Yellow Ignition Switch Harness
Tach Blue Distributor
Brake Switch Green/White Brake Switch
Trunk Pin Green/Black (-) Above Fuse Panel
Parking Lights Red/Black Above Fuse Panel
Head Lamp Red/White Steering Column
Door Trigger Green/Red (-) Driver's Running Board (One of Two Wires)
Door Lock Green/White (-) In Driver's Door at Door Lock Module or at Anti-Theft Module under Driver's Seat
Door Unlock Green/Red (-) Driver's Running Board
Horn Wire Blue/Red (-) Steering Column, use Relay
Windows Up LF=Red/Blue, RF=Blue/Yellow
Windows Down LF=Red/Yellow, RF=Blue/Green
Jan 13, 2010 | XX-67A II LED/Valet Switch Pod
Where is the Parking Lights+ wire on a 97 Civic
You will need to find out the color code of the park light feed wire from the headlight switch. Then, you should be able to locate the wire behind the drivers side kick panel as it junctions and splits there to feed the front and rear of the car.
Aug 14, 2009 | 1997 Honda Civic
97 Ford Windstar audio wiring diagram
1997 Ford Windstar Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Brown/White
Left Rear Speaker Negative Wire (-): Light Brown/Yellow
Right Rear Speaker Positive Wire (+): Light Brown/Green
Right Rear Speaker Negative Wire (-): Brown/Pink
hope this is the one your looking for pls rate
Apr 07, 2009 | 1997 Ford Windstar
1996/1997 Ford Windstar Audio wiring diagram
96 and 97 are the same
Apr 07, 2009 | 1997 Ford Expedition
Brand Remote Start/keyless/car Alarm Very Sleek Logo
971 people viewed this question
Top Spy Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Norman Al-Anbar
Kardoc
Are you a Spy Vehicle Part and Accessory Expert? Answer questions, earn points and help others
