2002 Audi A4 Logo
Posted on Mar 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a yellow triangle with an exclamation mark
I have a yellow triangle with an exclamation mark inside a horsehoe looking symbol on my dashboard help.....
Anonymous
Level 3:
  • Master 1,874 Answers
  • Posted on Mar 31, 2010
Anonymous
Master
Level 3:
Answers
1874
Questions
0
Helped
2167073
Points
7058
ESP = Electronic Stability Program malfunction indicator lamp (MIL)
1. You can try to disconnect the battery from car terminals, waiting for 30 minutes and connect again the cables in order to reset the ESP Electronic Control Unit (ECU).
2. If this procedure does not work you must use a diagnostic equipment connected to the Data Link Connector (DLC) of the car. The ESP ECU fault memory can only be accessed and erased using diagnostic equipment connected to the DLC.
Note: ESP function includes ABS (Antilock Braking System) function!
Anonymous
Level 3:
  • Master 510 Answers
Anonymous
Master
Level 3:
Answers
510
Questions
0
Helped
384451
Points
1812
Tyre pessure warning,check pressures,to reset check manual
2answers
What a yellow Exclamation mark inside a yellow Triangle means on a Skoda Octavia 2016 mode
The yellow exclamation point close to the center of the odometer looks like an exclamation point surrounded by parentheses. This light means you should check your tire pressure. Once you have checked the air in the tires and remedied any issues, push the "Set" button on the dashboard. The light should disappear.
Yellow oil light with exclamation mark
time for a service. or oil to low. time to top up.
What does the dashboard symbol of a triangle with an exclamation mark inside it mean for a Honda frv
if its appearing on the lhs off the dash its just when your tyres are losing grip whith the road surface.
1helpful
Exclamation point in triangle blinking on dashboard
Hi, The exclamation point in triangle blinking is the "Emergency Blinker" This blinker turns on all all of the turn signal lamps at all four corners of the car. Left and Right, Front and Back. The triangle represents the European symbol for roadside emergencies. In fact on European Mercedes and other cars there is a triangle shaped reflector you can put behind the car so that other drivers know you have an emergency. THAT TRIANGLE ON YOUR DASHBOARD IS A BUTTON. PUSH IT ONCE. THE BLINKING SHOULD STOP. If you have a roadside emergency, and are broken down by the side of the rode. Push the Red Triangle and your lights will blink on and off ouTside to say, in effect "help".
Hope this helps.
Best,
Mark
1helpful
2answers
I have a light on my dash with an exclamation point enclosed in what looks like parenthesis with verticle lines underneath. It's yellow. Do you know what it is?
If it looks like a deflating tire with an exclamation mark inside, its the check your tire pressure light.
If its a triangle with exclamation mark inside its the check engine light.
2answers
3helpful
2answers
The symbol is a yellow exclamation mark inside a
It is the Tire Pressure Mounted System (TPMS). It monitors the air pressure in your tires. If it is on, you have low tire pressure...or like me, it's just a faulty indicator. Mine came on, but I don't even have TPMS on my vehicle.
Top Audi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you an Audi Expert? Answer questions, earn points and help others
