I have a sonyericsson w910i and its on orange i put my orange sim card in my phone and i have got a lock on the phone so wen i turn it off and then on it ask me for a phone unlock code and i have forgotton my code is there anyway i can unlock it?
what is the brand of your phone and and what provider its locked to ................ if your NOKIA PHONE SAYS INVALID SIM or PHONE RESTRICTED ..IT MEANS YOUR PHONE IS NETWORK LOCKED.IT WILL ONLY WORK WITH A PARTICULAR SIMCARD ONLY PROVIDED TO YU BY UR SERVICE PROVIDER......YOU NEED TO UNLOCK IT IN ORDER TO USE THAT PHONE WITH ANY OTHER PROVIDERS SIMCARD...WE CAN UNLOCK ALL NOKIA IPHONES SONYERICSSON MOTOROLA HTC BLACKBERRIES AND MANY MORE ..CONTACT US ON gsmspeedAThotmailDOTcom
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here http://www.prounlocking.com/sony-ericsson-w910i/rs8wp9/
The phone lock code protects your phone against unauthorized use if it is stolen and the SIM card is exchanged. To be able to switch the phone on, you need to enter the four-digit phone lock code. The Sony Ericsson default phone lock code is '0000', but you can change this to any 4-8-digit personal code. When you buy the phone, the phone lock is by default turned off. Note: For security reasons, your operator, retailer or Sony Ericsson Contact Center cannot retrieve the lock code through the phone or the network. If you forget the code, locked phones must be sent to a service centre.
Depends where it was flashed. Take it back to the shop or if you did it yourself repeat the procedure but first take out the SIM and battery and then replace after a few minutes just in case. Also try another SIM by the same operator if the phone is locked if not any operator.
If no success, You can use Wotan website to reflash. You need to buy credits and data cable that came with the phone
http://www.wotanserver.com/en/supported-phones/sonyericsson-w910-debranding/
Some of the Sony Ericson phones have a little slider that slides back over the SIM card. This slider takes a bit of force, but be careful. Hold down the SIM and slide the retainer over the edge if the SIM.
Sounds like your phone is restricted to Vodafone. Each network generally puts a lock in the software to stop other network sims being used in it. If you know your phone is unlocked (sim free) then it could be that you have not activated your Orange sim card? Check the instructions that came with your Orange sim as i am sure that you need to call Orange to activate it? Hope that helps?
I have just tried it with my new locked to orange g600 and it works fine on all networks.
1-Turn on the phone without sim card . 2-Pull off the battery cover and insert any non-accepted sim card (without turning off the handset) 3-Do full reset *2767*3855# , phone will reboot and goes to Menu . 4-Customize Sp-lock code *7465625*638*00000000*00000000# 5-Unlock your phone with new SP code #7465625*638*00000000# 6-Enjoy G600 unlocked if it doesn't work after step 3.. try changing the 'non-accepted' sim card that ur putting in.. eg if you are locked to vodafone and you try this method and use an orange sim card and it doesn't work, try using a o2 sim or even virgin :) its easygood luck
By doing the reset (1st temp) you will lose all your data ie contacts, messages, photos, videos etc etc so back them up on your pc first.
Take out your sim card and follow the instructions below :
1st temp. put this number in the keypad *2767*3855# let it reboot(restart) now its ready for permanent.
Put in a sim card of a network that the phone won't except and follow the instructions below. ( If you can't type anything with a locked sim card inserted just take it out and do the next step without a sim card in the phone)
Don't worry if your screen shows - - - - - - - when typing it is supposed to do this.
Permanent.
ENTER :
*7465625*638*00000000*0000000 0#
NEXT ENTER
AND THEN *#7465625# to check the locks....all locks are inactive...these are all the locks... network lock - inactive subset lock - inactive sp lock - inactive cp lock - inactive sim lock - inactive activa lock - inactive phone lock - inactive auto network - inactive auto subset lock - inactive auto sp lock - inactive auto cp lock - inactive auto sim lock - inactive
Enjoy !
This procedure does not change your imei number at all
