Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
Posted on Mar 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Brush bar is scratching hardwood floors. It seems too low!
Dyson, Animal. Purchased about 3 years ago.
Jeethu
Level 1:
Habit-Forming:
New Friend:
  • Contributor 20 Answers
  • Posted on Sep 19, 2017
Jeethu
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
20
Questions
0
Helped
97631
Points
58
You could always purchase dyson replacement parts directly from Govacuum with an exclusive 11% discount for Fixya.com readers, use code: FIXYA11 to checkout to avail the offer. We also offer free shipping over $35.
Dyson Hose - https://www.govacuum.com/collections/vacuum-parts/vacuum-cleaner-hoses+dyson
Dyson Filters - https://www.govacuum.com/collections/vacuum-filters/dyson
Complete Dyson Products - https://www.govacuum.com/collections/dyson
Jeethu
Govacuum Team
Think Crucial
Level 3:
Master:
  • Dyson Master 894 Answers
  • Posted on Mar 05, 2017
Think Crucial
Dyson Master
Level 3:
Master:
Answers
894
Questions
0
Helped
710799
Points
8395
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller is not working properly. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
5 Related Answers
Anonymous
  • 372 Answers
  • Posted on Jul 05, 2008
SOURCE: Dyson DC07 Vaccum - brush will not turn
Hi.
Your Dyson has A clutch unit this engages the brush roller when you pull the handle back to vacuum.
Check the clutch control knob which is at the bottom left side of machine looking from the front.
It should rotate to drive position when handle is pulled back.
If it doesnt turn the knob by hand to drive & try the machine.
If you still have no brush rotation after doing all this then UNPLUG machine from mains supply.
Now lay machine on its side & remove the sole plate, This is the cover over the brush roller.
Turn the 3 plastic screws to unlock postition & lift sole plate off.
Now try to yurn brush roller using your hand. It should turn freely if it is difficult to turn look for any foriegn object obstructing the roller.
If no obstruction found then remove the brush roller from the machine & check the bearings in the ends of the brush roller one or both may be siezed up if they are then new brush roller will solve the problem.
If bearings are good then either the clutch is faulty or the second belt which goes clutch to motor has snapped & will need replacing.
It is difficult to fully explain the clutch removing procedure,
But there are service manuals available for these repairs at this site
http://dysonmanuals.llc.nu/
ukvacfan
Ryan S
  • 328 Answers
  • Posted on Apr 02, 2009
SOURCE: The brush bar on my Dyson DC17 stopped turning.
If this model has a brush control - i.e a roller at the side of the model which controls brush to spin or not, then its a protected brush model - therefore even if the drive belt is intact the Dyson would have to be repaired by a service personnel or professional. The brush protection isn't able to be taken apart and sounds like it may well have slipped off due to tension.
Anonymous
  • 7 Answers
  • Posted on Apr 18, 2009
SOURCE: My Dyson Animal 14 beater brush will not turn.
It MAY be a clutch issue. I had a similar problem with my DC07 Animal recently a posted a solution elsewhere on this site, but here's the summary. To reset the clutch on my model, recline the vacuum, turn it on it's side and slowly change the carpet/bare floor knob from one setting to the other about 6 times. This apparently reset the clutch and now it works fine. You may also wish to call DYSON. They're very helpful and walk you through troubleshooting before recommending servicing. Their number is 1-866-693-9766. They'll need your model and serial number (located on bottom of uinit).
Anonymous
  • Posted on Jun 13, 2009
SOURCE: DC15 Animal brush motor not working?
Same problem but all fuses etc ok I found that there are two wires that move with the head,orange & white located in the left hand bottom panel(side of vacume). they had broken bought some conectors from maplin & all fine now.
Anonymous
  • 3 Answers
  • Posted on Oct 10, 2009
SOURCE: Dyson DC14 Brush Bar won't turn
You don't need to take it for repairs, I just corrected the same problem on the phone with a tech. Have the head on your lap, make sure the end nearest the little belt has the rounded side of the bar facing you. The squared off end faces towards the machine. Place your left hand pointy finger under the bar (the 2 inch bar next to the little belt) and lift up, while finessing the loose end of the bar into place, with the rounded part still facing you. Then it sort of snaps into place. Now, replace the face plate. In the upright mode, starting at the carpet dial, switch the dial back and forth between carpet and bare floor, ten times. (the tech actually referred to this as re-setting the vac. LOL) Plug the vac in, incline the hand, and start. It should work. It didn't for me the first time and made a horrible sound. That meant I had to go and repeat the process again, but lo and behold, IT WORKED! When in doubt, call the tech and don't let them get away from you; have them stay on the line until the problem is resolved.
2answers
Why does dyson dc39 ball drag on floor which scratches hardwood and makes it difficult to push on carpet. Just started doing this after four years.
It sounds like the axle connections have gotten dirty or bound with animal hair or other material. Cleaning the axles can resolve this issue. Contact Dyson for assistance here:
http://www.dyson.com/support/repairsandservicinginformation.aspx
Ensure you have the correct model number and purchase date when talking with the representative.
Install brush bar dyson dc14 animal
Check the belts, it sound like you have a broken belt or a belt you didn't not reconnect
Brush wont turn on my dyson....only had for 4 months....what do I do with this piece of crap?!?!
I agree. My store stopped selling Dyson 8 years ago. Before you toss it out, take it to your local vac shop for diagnosis. They can repair it or take it on trade for a quality vacuum cleaner.
My Dyson 14 Animal seems to not have the suction
Hi its Darran at Dyson.
Firstly check that the brush bar control on the cleaner head is in the correct position. You may have switched the brush bar off the last time you used it or the dial may hav got knocked when you vacuumed under some low furniture.
If this is in the correct position but the brush bar is still not turning, switch the machine off and remove the soleplate by turning the 3 fasteners on the base of the machine and checking for blockages and remove any threads or hairs around the brush bar.
I would recommend washing the filter if it hasnt been done for a while.
You may find it useful to follow the blockage procedure and filter washing instructions in your user guide, however if you no longer have this available you download a replacement for free via the support section on our website at www.dyson.com.
I hope that this information is useful to you.
Kind regards
Darran
Dyson Customer Service
1helpful
2answers
I have a Dyson Animal vacuum - about 3 years old - and the beater bar won't turn. I can't find my manual anywhere - any suggestions as to the cause?
There is a part under the knob that adjusts from bare floor to carpet that goes bad on these vacuums. I have an animal that is about 3 or 4 years old and I had it repaired last year( to the tune of $115.00), and it broke again in December, so I just bought a new one, tired of paying high repair cost!!
When I turn on mt dyson is sounds normal. once I
With the DC14 in its upright position, and looking from the back, there is an access hatch just to the right and bottom of the dust canister. Remove this and check for any obstruction. With the hatch still removed, tilt the handle back (as if vacuuming a floor), and you should spot that the mechanism in to which the access hatch fits changes over from one hole to another. This is how suction is transfreered from the telescopic arm to the brush bar when the unit is taken out of the upright position.
With the handle tilted back, the hole you can see is one end of a flexible pipe that leads to the brush bar. Check for any blockage and/or foriegn objects. If there is no obvious problem, you'll need to check the other end of the pipe. You can do this by removing the toe plate on the bottom of the brush bar area. The plate is held by 3 or 4 half turn fasterners - a 5 pence piece is ideal for undoing these.
If still no joy, the only other thing it might be is that the brush bar isnt spinning - this isnt actually lack of suction, but without brush rotation any upright hoover is far less effieicnt at picking up bits from the floor. Brushes not spinning on a DC14 is quiet a difficult thing to fix on a DC14 as there are two separate rubber belts, one of which is hidden under a plastic cover. There is also a clutch mechanism between the belts that can cause problems some times.
2answers
My dyson animal is hard to push on carpet - the beater bar is still operational. When I turn off the beater bar and run the vacuum on hardwood the beater bar stops moving, but it still ''rolls'' on the...
If suction is not what it was, check all of your hoses and connections for vacuum leaks. And the beater roll should always be turning - check out the belt for slippage.
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
