Empisal Super Star sewing machine uses a set of stitch pattern cams to create different stitches. If you need stitch pattern cams for your Empisal Super Star sewing machine, you can try the following options:
Check with the manufacturer: Contact the manufacturer of the Empisal Super Star sewing machine to see if they still produce or have stock of the stitch pattern cams.
Check online marketplaces: Look for online marketplaces that sell vintage sewing machine parts, including stitch pattern cams for Empisal Super Star sewing machines. You may be able to find them on websites like eBay or Etsy.
Check with a sewing machine repair shop: Contact a local sewing machine repair shop or service center to see if they have any stitch pattern cams that would be compatible with your Empisal Super Star sewing machine.
Consider alternatives: If you are unable to find the original stitch pattern cams for your Empisal Super Star sewing machine, consider using alternative stitch patterns that do not require cams. You can also consider purchasing a newer sewing machine that has a wider range of built-in stitch patterns.
It's important to note that not all stitch pattern cams are compatible with all sewing machines, so make sure you check that the cams you purchase are specifically designed for the Empisal Super Star sewing machine model.
Wish I could see your whole pattern, but anything between stars means repeat between stars.
it could mean increase between stars to...to end? Or until so many stitches.?
Like I say I would need to see more of the pattern.
90 lbs. and torque them in a "star" pattern, otherwise the wheel will not be mounted correctly and will vibrate at high speeds. By star pattern... I mean not circular, hence torque each opposite stud in sequence and it will work perfectly.
sounds like a damaged screen or "display panel" which are used in LCD and Plasma sets----damage to it is fatal as the part wholesale costs more than the set did when brand new.
Sony wega blue dot or star pattern on screen http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655 Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620 Sony LCD Rear Projection TV - Optical Block Problems http://splinke.googlepages.com/sonyrearprojectionlcdtv-opticalblock
