Microwave Ovens Logo
Posted on Mar 31, 2010
Emerson MW8999SB 900-Watt Microwave replacement plate
I have an Emerson MW8999SB 900-Watt microwave oven, and need a replacement plate. What size is it?
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Mar 31, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3320
Points
18
From what I could find, it should be 10 1/2 inches in overall diameter.
meowpfttpftt
Emerson red 900 watt microwave glass turntable
Replacement trays cost around $30.00. The cheapest I found was on Ebay for $28.00. By the time you pay for shipping you can almost buy a new appliance. Also take care that you find one for your model, you can't always tell by looking if it is going to fit.
Try your local Goodwill or other thrift store for a used one.
Good luck
1helpful
Emerson microwave not working 900 watts
The Emerson MW8999SB 0.9 cu. ft. 900 watt Microwave Oven is relatively compact, and certainly inexpensive, but doesn't skimp on functionality. We were surprised at all the options you get with this little microwave. It's only 20 inches wide, 11.3 inches high and 16.1 inches deep yet. The interior can still accommodate a regular size dinner plate or small (10-inch-square or round) casserole. Plus, there are 10 power levels, eight one-touch function buttons, six Express Cook settings, timed and automatic defrost options, and a rotating glass turntable to circulate the food for more even cooking.
We were very pleased with the performance of the Emerson MW8999SB. It did a fine job heating water for tea, cooking a couple of baked potatoes, reheating leftovers and steaming fresh vegetables. Even the automatic defrost proved surprisingly efficient, letting you enter the weight of the item(s) to be defrosted (4-100 ounces) for easy operation. Chicken breasts were almost fully defrosted after one cycle. We needed to stop and separate the food pieces to finish the defrost cycle.
The unit is styled mainly in black but has stainless steel trim around the door and control panel. The smooth touchpad control panel is attractive and easy to wipe clean. We loved the one-touch Express Cook buttons, which let you activate the unit at 100 percent power for 1-6 minutes, by pressing the corresponding number pad. We also appreciated extra touches such as the Start/+30 sec. button, which can be used to start the oven or add an extra 30 seconds each time it is depressed.
It's hard to go wrong when the functions are so simple. The only tricky part was identifying certain codes used on the display screen. When changing the power level, for instance, PL10 is displayed on the screen. Pressing the button additional times lets you toggle through the different levels. Likewise, the Auto Cook settings may need to be pressed multiple times to obtain the correct weight or portion for the food being cooked.
We were amazed that a machine costing so little also offered two-stage cooking, which lets you start cooking (or defrosting) on one setting and finish on another. All in all, the Emerson MW8999SB is an excellent value.
Pros: Touchpad controls, eight one-touch function buttons, six Express Cook settings, two-stage coking option
Cons: Limited interior capacity can only accommodate dishes up to 10 inches, no sensor
I HAVE A MICROWAVE MODEL EMERSON MW8999SB IS NOT HOT
I unplugged mine and let it sit for a few mins then plugged it back in and it works again....Yeah Me!!!!!!!!
Emerson mw8999sb rattles when running?
It is probably the turntable glass platter that is rotating when the microwave oven is running, this is not uncommon and nothing to worry about.
Model MW8999SB is not heating anything?
If the microwave powers up and everything appears to work then the problem is the magnetron, "heats food and is the heart of the unit" it is cheaper to replace the whole oven rather having it repaired.
On the Emerson MW 8992 SB microwave oven how does one change power settings,e.g., from 100% to 50%?
Emerson MW8991SB 0.9Cu.Ft. 900 Watt Touch-Control Microwave Oven, Stainless Steel has the same face as your microwave. I own one of them Look at the bottom three uo to the left it says (POWER) push the Power button it starts at 10 and goes to 1. 10 being the highest and 5 being half power and 1 being the least. then select the amount of time you will cook by punching in the numbers.
2answers
How many watts does Emerson MW8675W Microwave have?
Is the cubic foot size of the microwave on the name plate?? It seems that with Emerson the size relates closely to the wattage .. 0.9 cu ft is 900 watts, 1.1 cu ft is 1000 watts .. 0.7 cu ft is 700watts .. That would be the closest info I can get.
Please vote !!
1helpful
Emerson 900 Watt Microwave MW8991SB glass turntable broke in two Replacement parts anyone?
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating an authorized servicer or parts at 1-800-695-0098.
Emerson parts are distributed by Fox International and their number is 800-321-6993. Or you might try e-mailing [email protected]
Many Emerson microwave owner's manuals are available for free download here.
Even though yours may not be there, there might be one close enough to help you .
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
