Most likely the lid seal and/ or the detergent dispenser seal is leaky. Do not operate the dishwasher in this condition as the water can cause electrocution because the mains voltage comes up to the drawer front panel. Most likely it is the detergent dispenser seal.
first make sure your detergent drawer is not popping open. water will run out from beneath the drawer, run over to the top of the door, run down the door, and then straight down to the floor. If you are not leaking out of the detergent drawer, the next thing down is the bottom of the glass door. look at the glass where it contacts the door seal at the bottom. It should be clean and smooth. Most likely you will find lint, hair, and soap residue. that needs to be cleaned off. any surface imperfections will cause a slow drip or trickle of water to come out of the lowest part of the door. If that is fine, and it is still leaking, open the cover to the drain pump on the bottom right of the front of the machine. Make sure that drain pump filter is tight. run the machine with that little drain access door open and see if you are leaking from there. If none of the above helps, and you are still getting water leaking from the door, miele has designed a new clamping ring for the door seal. Call them and make arrangements to have it replaced.
Normally caused by undissolved soap residue. Switch off machine from mains, Remove detergent drawer from washing machine, there might be a small plastic clip that need to be levered by hand before the drawer can come out completely. Soak detergent drawer in a tub of water, rinse under tap and wash thoroughly until all soap residue has been washed away. Replace drawer.
remove the drawer and clean the siphon it sounds as if it is blocked up either with powder or concentrated fabric softener. this should fill up with water and then empty itself due to gravity. the siphon should look like an upside down cup on a cylinder.
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets 1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems. 1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open. 2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct. 3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart. 4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door. 5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart. 7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem. 15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine. 15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
If this is a front loader see that u use only washing powder for FRONT LOADING MACHINES. Also possible your detergent drawer is clogged with old dry detergent. Pull out the drawer and clean with tooth brush. Things shd be fine.
Possible your detergent drawer is clogged with old dry detergent. Pull out the drawer and clean with tooth brush. Things shd be fine.
Also use only detergent for 'front loading machines'.
Hotpoint WF430 Front Load Washer
This video will show you how to find that leak on any front
loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
