LG Dishwasher model:LD-2040WH E1 code display on mashine, I don'tsee any leakage or blocked RiaTel 0836545141
If you've checked everything, you will need to replace the impeller possibly.
Leakage error > Conditon: Excessive RPM of washing motor happened
during wash cycle due to water leakage.
Possible cause: Water leakage in hose connections,water is leaked by
damages. The motor water seal leakage of sump assembly. The height of
drain hose connection ( sink drain hose ) is not over 20". Impeller of
the washing pump is worn away.
Hi
E1 is a leakage error in your LG dishwasher; it is usually
displayed either due to a clogged drain or due to water leakage in hose
connections. If the drain pump assembly is not clogged then check the motor
water seal leakage of sump assembly and also check the impeller of washing
pump, if it is worn then replace the impeller. You can also make sure that the
height of drain hose is not over 20". Hope this helps...please post back for
further assistance.
Daniel
The main water pump on this model does not last long. The water seal between pump and motor starts to leak that result in the adjacent motor bearing corroding and eventually failing, resulting in excessive noise. Later the water leak becomes so bad that it triggers the "E I" water leakage display and prevents it from completing the program. The pump and motor is sold as one unit and the whole unit must be replaced. I have tried to replace the faulty bearing and repacked the rubber seal with silicon grease but with no success. If anyone have repaired the water seal successfully please let us know.
NEED SERVICE MANUAL FOR LD-2040WH
