I have an Oakley D2 watch that has a rubber watch band/strap. The small rubber ring that keeps the buckle end of the strap connected to the band has ripped. Any idea where I can find a replacement? Thanks!
You can buy any rubber watch strap and take the loop off for replacement. Just make sure - the strap you buy is exactly the same width as the original ******** your watch. Needless to say: colour should match as well. Rate me, plz.
Remove the deployant clasp from the watchband. The clasp is attached using spring bars on each end of the clasp. The method of spring bar removal varies but is usually performed by pushing a small pointed tool (one end of a spring bar tool) into a hole at the end of the clasp. While depressing the spring rod, pull the buckle away from the bracelet to detach. Repeat this for both sides of the buckle.
Step 2
Measure the watchband to determine proper sizing. Use the scissors to cut along the inner grooves to remove needed sections (each section of the rubber will contain a new set of holes for the bracelet spring bars). Cut carefully and conservatively, as this step cannot be undone.
Step 3
Reattach the buckle to the band after resizing. Reverse Step 1, pushing the spring bar in while sliding the buckle back into place.
jQuery('.article ol .image').each(function(i,e){
var $this = jQuery(this);
$this.find('img').error(function(){
jQuery(this).remove();
$this.remove();
mcdevito75 here, If your Casio has a metal band, you can remove 1--2 links, this takes a special tool called a link remover, best bet is to look for a small watch repair shop in your area. If your Casio has a strap, the buckle may be able to move up the strap to fit your wrist, if so, move the buckle up the strap to fit your wrist and cut offf the exccess strap. If not, you"ll have to replace the entire strap. Hope this helps.
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
I will give you the generic answer as I have not actually removed a Cartier buckle. Most buckles use a small bar called a spring bar that goes through the band and "tang". The ends of the bar are like a plunger in that with a small fork like instrument or small screw driver you can collapse the bar and move it out of the clasp. The rest is very obvious. Replacement is the opposite of removal. A fairly simple procedure for most people.
The following proccedure mentioned can be implied for replacing only resin(plastic) strap.
If you have a spare Band, you can replace it with the help of one small four mouth screw driver and one small 1, 2 or 3 no. screw driver which you can get from any electronics/ computer hardware shop.
Band = Strap
You just need to remove the strap with the help of 1, 2 or 3 no. screw driver which ever you find convinent by removing the Spring Bars. After removing the strap put out spring bars from both sides as these may be used for again fixing the band.
If you find difficulty in removing the Band, you just need to unscrew the screws on for side of the watch case and remove the ring and after fixing the strap you can fix the ring again.
The new band can be fixed in the same way as it has been removed. You need to put the spring bar in the hollow space of strap and keeping the buckle side part of starp above the watch i.e 12 position over the space where it has to be fixed, then put one end of the Spring bar on one hole in the watch case and press the spring bar to get inside from other side (hole in the watch case). In the same way you can replace ******** other side.
In case of any difficulty take your watch to nearest Casio Service Centre for assistance or solution of problem.
