Did you check the wiper relay's in the under hood fuse box ? There are two ,wiper run/park relay & wiper high low relay ! Also ,did you check fuse's ? fuse # 11 - 30amp location cental juction box . The wiper switch is a input to the GEM module . Generic electronic module . The module in most cases isn't the problem ! Learning how to test these electronic systems is , people do not know how to test so they just replace parts . What they should do is take the vehicle to ford certified Technician who has the knowledge and testing equipment to find an fix it .
The generic electronic module (GEM) receives inputs from the following:
multifunction switch
anti-lock brake control module (vehicle speed signal [VSS])
ignition switch
The GEM uses these inputs to control the outputs to the following:
windshield wiper high/low relay
windshield wiper run/park relay
windshield washer relay
rear wiper motor relay
rear window washer relay
GEM Diagnostic Trouble Code (DTC) Index
DTC
Description
Source
Action
B1240
Wiper Washer Rear Pump Relay Circuit Failure
GEM
GO to Pinpoint Test K .
B1241
Wiper Washer Rear Pump Relay Circuit Short to Battery +
GEM
B1342
ECU is Defective
GEM
CLEAR the DTCs. REPEAT the GEM self-test. If DTC B1342 is retrieved, INSTALL a new GEM. REFER to Section 419-10 .
B1431
Wiper Brake/Run Relay Circuit Failure
GEM
If the windshield wipers are inoperative, GO to Pinpoint Test B .
If the windshield wipers stay on continuously, GO to Pinpoint Test C .
B1432
Wiper Brake/Run Relay Circuit Short to Battery
GEM
B1434
Wiper Hi/Low Speed Relay Coil Circuit Failure
GEM
GO to Pinpoint Test D .
B1436
Wiper Hi/Low Speed Relay Coil Circuit Short to Battery
GEM
B1438
Wiper Mode Select Switch Circuit Failure
GEM
If both the windshield and rear window wipers are inoperative, GO to Pinpoint Test L .
B1441
Wiper Mode Select Switch Circuit Short to Ground
GEM
B1446
Wiper Park Sense Circuit Failure
GEM
If the intermittent windshield wiper speed does not operate correctly, GO to Pinpoint Test E .
If the speed dependent interval mode does not operate correctly, GO to Pinpoint Test G .
If both windshield and rear wipers are inoperative, GO to Pinpoint Test L .
B1450
Wiper Wash/Delay Switch Circuit Failure
GEM
If the wash and wipe function does not operate correctly, GO to Pinpoint Test F .
If both the windshield and rear wipers are inoperative, GO to Pinpoint Test L .
B1453
Wiper Wash/Delay Switch Circuit Short to Ground
GEM
B1458
Wiper Washer Pump Motor Relay Circuit Failure
GEM
B1460
Wiper Washer Pump Motor Relay Coil Circuit Short to Battery
GEM
B1473
Wiper Low Speed Circuit Motor Failure
GEM
If the windshield wipers do not operate at high or low speed correctly, GO to Pinpoint Test D .
B1475
Accessory Delay Relay Contact Short to Battery
GEM
REFER to Section 501-11 .
B1476
Wiper High Speed Circuit Motor Failure
GEM
If the intermittent windshield wiper does not operate correctly, GO to Pinpoint Test E .
B1611
Rear Wiper Mode Switch Circuit Failure
GEM
GO to Pinpoint Test H .
B1614
Rear Wiper Mode Switch Circuit Short to Ground
GEM
GO to Pinpoint Test I .
B1820
Rear Wiper Motor Up Relay Circuit Short to Battery +
GEM
B1839
Rear Wiper Motor Circuit Failure
GEM
All other DTCs.
GEM
The wipers on that vehicle work with vacuum, if the vacuum is low, (which it would be sitting at an idle) then the wipers will slow or even stop,, try reving the motor just a little to see if that improves the problem, if it does, Lube the mechanical portions of the wiper assembly ,,
Car has rain sensing windshield.Most likely you have the wiper on/off level in the intermittent position,which turns on the sensor. When the sensor detects moisture or even dust sometimes. It turns on wipers. Just make sure the wipers are off and not in the intermittent position.
The dealer near me charges $365 for a 4-cyl, $395 for a 6/8 cyl, or $425 for a 12-cyl. The only actual repair/maintenance you get for that price is an oil change (with Mobil1 and the MB filter, which are CRITICAL, ~$120 on its own) and tire rotation. This makes a lot of people think it's a scam, but really, it's a little steep, but definitely worth doing. The rest of the service consists of a massive inspection of your vehicle covering the following items.
-- Fluid levels -- Tire tread/pressure/wheel condition -- Air filter (inc. clean out housing) -- Cabin air filter (inc. clean out housing) -- Lubricate sunroof rails, locks, hinges, and seals on body. -- Drive belt and tensioner -- HVAC system operation -- Instruments, cruise control -- Wipers/washers/lights/horn -- Windows/sunroof operation -- Hoses -- Transmission fluid -- Brakes -- Chassis/suspension -- Driveshaft, inc. flex discs -- Road test -- Reset maintenance light
This is actually pretty essential to do, despite seeming like a lot of money for not much work. I have very rarely done one without catching a few things that the customer needs, and often it was a problem that would have gotten far worse had it been left to its own.
