I suspect both of you have a failed main power supply, this model may not be well-protected against brownouts or surges.
The main supply is usually a separate board and if you remove the lower rear panel, look for a board that seems to be related to the AC line and has larger components than the other boards.
Some of them will be cylindrical and others block-like.
Look for a board number since this is a component that is often outsourced and may not be from the same manufacturer in every set.
Call the nearest service center to inquire about repair or replacement costs.
I have a WD-52725 and I can get it to come on for about 10 min then it goes off and the green light will blink and I can't turn it back on. The only way to get it back on is to unplug it for a while and then plug it back in and the same thing happens again. Any thoughts?
Or the capacitors are Bad where board 3 will not talk to board 1
tyhat is 1,2,3 as they are installed it the chassis
there was a fix for this posted ealier check back on older post
Jim
I have the same problem, if you find a solution that would be cool @ [email protected] Thanks If I find the answer i will post it here.
SOURCE: Model WS-55909 Green light flashes won't go out. No TV
You need the WS55909 - WS73909 DM kit. You can get it at the following link which contains the capacitors and the CD with instructions on how to do the repair.
http://www.tvrepairworld.com/
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
