Go to Device Manager and enable the audio card.
If you cannot enable the audio card or it is not working then install the audio driver again.
Testimonial: "Thanks for the quick response and good info, it was very helpful."
Thanks, The problem appears to be when I install the Delta 66 it corrupts the SoundMax software. re-installing SoundMax will not work because it gives a no HDA driver found. The only remedy I found was to remove the Delta 66 and reinsatll the chipset and the audio drivers. This will return th efunction of the onboard sound card but as soon as a re-install the Delta 66, I'm back to the same old problem.
Would an alternative solution be to install a pnp Sound Card compatible with Delta 66?
