You can do this by simply holding down the Power/Menu button for about 15 seconds. After the reset, any changes you have made to the e200 during its last use will be lost.
Most common solution hold the rec botton while the lock menu is pressed for 15 sec
My sansae260 has the problem that when you turn the logo appears to no good but thenasks me free 60 mb but when I connect to the computer does not recognize thesolution please help me I could send my email thanks [email protected]
I have a problem with the battery not chargin
Rhapsody, Media Center, and Real Player do not see the Sansa when I connect it to the PC. The PC does see it and does add it the drive/map configuration. I am able to open the Sansa folder and peer into it, but I am unable to change it in any way.
Rhapsody 250 purchased 2 years ago at Best Buy.
Please email me at [email protected] if possible.
Thank you.
SOURCE: how to restet my sansa e260
Menu - Settings --> Reset All
This option will reset all the Sansa e200 player’s settings back to
factory defaults.
SOURCE: sansa e260
Hola a todos, les dire que tengo un Sansa e260 y el problema que tiene es que cuando la conecto a la pc la reconoce como USB Device y no la instala y la pantalla se queda en negro, ya tengo su firmware y su rom, solo quiero ver como resetearla o algo.
porfa, ayudame si pueden
[email protected].
SOURCE: problem with sansa e260
It is because the e260 is not in MSC mode (where it looks to the computer like a hard disk).
Try this, this will temporarily set your e260 into MSC mode. Then download and install the firmware as per instructions (or use the Sansa Updater software also available on the Sansa site). This will then let you see a menu item to switch to MSC mode.
MSC mode instructions:
http://forums.sandisk.com/sansa/board/message?board.id=e200&thread.id=10357
when i turn it on the screen comes on for about 3 seconds and turns off, when it turns on the screen is white, what can i do to fix it?
how to reset sanda 260
The songs that are on the mp3 player will not resister on the computer ..... this situation will not allow me to delete songs off the mp3 player!
helpp plizzz it wont let me delete any of my songs!! how can i reset it???
how do i reset my sansa e200???????????
my sansa keeps repeating the first thng that shows up saying sandisk over and over again and dosent show up on my computer. whats do i do to fix it help please.
my sansa Goes to welcome menu and says SANDISK and whites out and comes back again and does the same thing over and over again how i fix
