Well blow by is when your rings are gong bad and allows compression to pass the rings and preasurize the crank case and ya it could push sum oil up that tube to soak that little filter if you have it running take off the oil fill cap and if you have blow by it most of the time will smoke out the fill hole
Testimonial: "Thanks for the input! I will try that ASAP!"
Your PCV valve is usually about a $2 part and is suppose to keep oil out of this tube. Follow the tube back to the valve cover and the PCV valve should be there.
Excessive blow by could also cause oil to get into this tube. The blow by is usually caused by worn piston rings or valve guides. The compressed air/fuel mixture or exhaust pushes past these areas and make it into the crank case. Usually if you have a lot of blow by, you'll see your dipstick tube popped out a bit too.
PCV valve is cheap and easy to change... I'd give it a try.
Testimonial: "Thanks for the quick response! I will try it first thing tomorrow!"
