You have to format your micro SD memory card with your phone first before you can download files to it. With the micro SD memory card in your phone.
1)go to menu 2) go to settings & tools 3)go to memory 4)select card memory 5)***SELECT OPTIONS*** ---this will ask you if you want to format your card select YES, if there is a phone password it would be your last 4 digits of your number.
Now eject the memory card from you phone. Now when you put the memory card to your computer you should see the sub menus...my pics..my videos...my music...my sounds. Now all you have to do is just click and drag your music and photos to these folders.
Then when you add the memory card to your phone it will see all the music, photos, etc...
I Cut off my Nokia 6126 cell phone to remove micro SD card (2 GB), but having problem doing so. Is there some button to press to remove the memory card?
Same with me
SOURCE: memory card
I was having same problem with a 4 yr old digital camera. Apparently, it only recognizes up to 512 MB, and the card needs to be partitioned into 4 parts.
my 1gd sd mirco card won't work when i put it in
meine sd card (gebraucht) lässt sich nicht lesen
yeah..
my phone does not detect my memory card on an on and off basis
when i tried to access the files in the card it just shows "No files" when i have a bunch in them.
I know the memory card is still not faulty as i can still access the files from my computer.
i put an 8 gig card in and cannot format it
SGH D600 phone
Pls advise
Thanks
I can't figure out how to get music from the sd card to the phone. I know the files are on the card. I tried formatting the card from the phone...the phone asked for a code that I have no idea what it is. Lock code or something. I'm so confused. I love my env2 but this one problem is frustrating me to no end.
