Uniden BC898T Base Scanner Logo
Posted on Mar 30, 2010
I think there is something going on between 1 or more of the three buttons namely "SEARCH,SCAN,TRUNK" that won't let me use the trunk system automatically. I have to use it manually .Worked great for 3 years and just stopped trunking I think the radio may have gotten tired because it had to do so much.
Anonymous
Level 1:
  • Contributor 68 Answers
  • Posted on Apr 16, 2010
Anonymous
Contributor
Level 1:
Answers
68
Questions
0
Helped
19714
Points
85
Yep, sounds like the contacts on the keypad are worn. In most cases i have been able to resolve that issue here on the bench. Let me know if you'd like to ship it in. Dodgem250.com
The trunk is closed but has a space. I push the button to open the trunk and it does not unlock. It tries to close shut but can't?
Question edited into sentences and to what I think you thought you were saying.
'year make model' as first three words in every question please. There are categories for every model and in most cases the year as well.
Open the trunk and use the emergency handle release to release the catch. You will see it is currently in the locked position with a closed latching hook. Spray it with WD40. With the truck OPEN, get someone to operate the trunk release button and you should see it move a little. Then lock it again.
You can Google
year make model trunk won't lock
https://www.google.com/search?q=%E2%80%8Byear+make+model+trunk+won%27t+lock
2014 Volkswagen Beetle Convertible r line trunk issue
I would have someone repeatedly press the release button whilst someone pulls up on the trunk.
If that doesn't work, call out out a mobile auto locksmith. They have 'tricks'.
Some videos here
https://www.google.com/search?q=2014+Volkswagen+Beetle+Convertible+trunk+won%27t+open
The three buttons on the interior (Trunk, Gas, traction) stopped working.
take it back to shop that did work and have them repair it free
Brake lights keep blowing fuse, Trunk indicator light won't go off with trunk closed
may have a short could be a bare wire recheck the brake switch make sure that the switch is not touching and metal.
____________________
BMW b800 srs airbag scan/reset tool
Trunk won't open
Lower the back seat and crawl into the trunk and see what the latch is doing when you activate the key fob. the trunk lid will have to be open to enable any repairs. Also an emergency release cable is probably visible (yellow handle) inside the trunk and will Open the trunk lid.
5helpful
2answers
My trunk won't open, I have tried my trunk button and the key won't work, it worked fine a few hours, but even when i try to do it manually it won't open. Also I would look in and try the...
There are 3 phases to fixing your car's trunk lid release problem.
Phase 1: First check the fuse - once you know that's OK, then proceed to phase 2 (below).
The fuse for the trunk lock is
the bcm (pwr) 15A fuse in the instrument panel fuse box (behind panel at drivers right foot)
Check that fuse, as it is the power supply for the button on the dash that sends power to the actuator in the trunk.
Phase 2: Get the trunk open (without taking it to the dealership).
If you have remote keyless entry to the trunk, you could try that - but with the actuator
dead/dying, it shouldn't work.
Here are a couple of ideas to try to enter trunk while (a) actuator isn't working, and (b) all
valet lockout features (designed to deny valets access to the trunk) are in the "Lock" position:
There is the lock cylinder, which you stated is not functioning - put the key in, and it doesn't
turn. Just to be sure, consider: lubricate key with Graphite lock-type lubricant, and retry.
The trunk has 2 valet safetys...the locking rear seats which require access to the trunk to unlock, and then there is a valet switch in the trunk that locks the button on the dash from working to keep valet parking attendants out of the trunk. That may be in the lock position.
You can try accessing the center area of the fold down rear seat and see if you can unhinge the rear seat from there. Maybe reach in with your hand, or an extension-type tool.
there may be a way to fold the hinge away from the seat back so it can be removed from the hinge and give you access to the safety latch in the trunk and open it that way (white handle in trunk).
The white-handled safety latch release is desiged to prevent accidentally trapping children, and
if you can pull it with your extending-type or grasping-type tool, the trunk will open whether or
not the actuator motor is working.
Phase 3: Replace the Problem part.
Your failed part may be either (1) Trunk Release Relay, or (2) Trunk Lock Release Switch
My Satrun ION manual doesn't cover either of these parts, and the online parts houses, e.g.
http://www.rockauto.com/catalog/x,carcode,1431624,pgname,Electrical-Switch%2B%2526%252338%253B%2BRelay,a,search.yahoo.com%2BSearch%2Bfor%2B2004%2BSATURN
fail to provide instructions. One of those times a mechanic has to t=rely on his/her native
handiness and/or experience.
To identify which of these parts is bad, locae the Trunk Release Relay (call your dealer parts
dept. for helpful tips on finding it), then operate the dashboard trunk release button with your
ear close tothe relay - if it makes a noise, the problem is the Trunk Lock Release Switch in
the trunk lid, otherwise its the relay.
Top Uniden Radio Communications Experts
John
John
eradiostore
eradiostore
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
