Sony KV-32S45 32" TV Logo
Posted on Mar 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My aunt who has an KDL26U2000 sony tv and has it too loud.She is driving her neighbour crazy.Please tell me how to set the volume so it will not be allowed to go any higher.
Ambari
Level 3:
  • Master 901 Answers
  • Posted on Mar 30, 2010
Ambari
Master
Level 3:
Answers
901
Questions
0
Helped
251594
Points
1858
Check the manual. See whether volume lock menu is there!
Then lock to the desired value & keep the volume lock in ON position.
Hope she does not know to re- set it!!
Panasonic TV does not play through surround speakers
so it is a connections problem I think. Check if video and audio cables are properly connected. Use color codes as your guide. Also from menu check if all settings are ok. Good luck
I HAVE A SONY KDL-V40XBR1 AND THE SOUND DOES NOT GET VERY LOUD. IT IS GOOD SOUND BUT NO MATTER HOW LOUD YOU PUT IT IT IS ONLY AVERAGE. EVEN GOING THROUGH THE SURROUND SOUND, SO I'M THINKING IT HAS
Your TV has 2 settings that could potentially affect this volume. One, verify the Audio Out option is set to Fixed. This allows your surround to control the volume. Two, make sure Volume Offset for each input could be set low, verify that isn't the case. Hope this helps.
Set clock on Pioneer DEH-P4400 car stereo
I GUESS, YOU DON'T HAVE OWNERS MANUAL. I RAN INTO THE SIMILAR PROBLEM, HAVING THE MANUAL ON HAND. YOU MUST BE VERY PATIENT: THERE IS A SEQUENCE OF MOTIONS TO SET THE CLOCK: THERE ARE COUPLE BUTTONS, I.E: SEL(ECT), ADJUST(VOLUME CONTROL) OR +/- BUTTONS. USUALLY "SEL" MUST BE HELD FOR A FEW SECONDS, THEN YOU SCROLL TO FEATURE : BASS, TREBLE, LOUD, ETC. USE VOLUME OR SCROLL BUTTONS TILL YOU REACH "SET CLOCK." SOMETIMES: + CHANGE HOUR, - CHANGE MINUTES. AND SO ON. BUT: GET OWNERS MANUAL, IF POSSIBLE. OTHERWISE, IT WILL DRIVE YOU CRAZY AND TIME CONSUMING.
TRY "GOOGLE"
http://audio.manualsonline.com/manuals/mfg/pioneer/dehp4400_dehp44.html
GOOD LUCK,
ALEX'S TV.
Sony bravia chirping audio
It's likely that the volume on your cable box at the new place is set much lower than your old place, so you have to turn it up.
Turning up the television too loud will cause the annoying chirping in some cases.
Try using the cable box remote, and turn up the volume on your cable box, as you turn down the volume on your television.
1helpful
Which is a better tuning setup for good quality bass ?
The KAC-8401 has a bass boost switch. Be sure that is on +6dB setting.
Secondly, LPF (low pass filter) should be selected, with the crossover cutoff set to 60Hz.
Follow the instructions on this site for accurate tuning....
http://trussinme.com/Apps/audio/voltagecalc/default.asp
Manual For Download:
http://inform3.kenwoodusa.com/manuals/KAC8401.pdf
There is so much bad information and VOODOO going around the internet about how to set car audio amplifier gain controls that I thought I better write this. Gain controls on an amplifier are basically just small potentiometers (variable resistors) or volume controls if you will, that allow you to adjust the incoming signal to the amplifier so the amplifier works well with your headunit of choice or to match the level of other amplifiers in your system.
Its not rocket science to set the gains. Gains are like little volume controls, (I don't know why so many installers are taught that gains are NOT volume controls, when in fact that is EXACTLY what they are!) its super simple to just set them where the level sounds good to you.
With one amplifier its desirable to have a nice swing on your headunits volume control. Let me try to clarify this a little.
If we hook up a head unit with a 8volt (or more) output to an amplifier, then the volume will get loud very fast when we start to turn it up...In other words if our digital volume control goes from 1-30, then a HIGH VOLT output to an amplifier might make the amplifier reach full power at 5 on the volume scale... That kinda sucks cause it would be nice if you had a little more swing in your 1-30 range!
And by the same token a headunit with a LOW VOLT output might have to be turned up all the way to 30 and might still not quite drive the amplifier to full power... That sucks too!
A gain control in this case will allow you to adjust the amplifier so it allows the volume of a headunit to control the amplifier so it will get loud at a desirable point in the 1-30 swing... Usually about 3/4 the way up. We don't want it to get loud too fast as we wont have a good control as music levels differ. And we don't want it to have to be turned up all the way to get loud either, because since different music may be recorded at different levels if we set the gains for max output with one music source it might not get loud with a music source recorded at a lesser level.
So, by setting the gains so 3/4 turn of the headunits volume knob gets it LOUD gives you plenty of control and some extra above the 3/4 mark in case you get some music that's recorded at a lesser level...
To do this its easiest to do it by ear. No need to drag out the TEST TONES and OSCILLOSCOPES! They will do you absolutely no good.
One MYTH is how the gain controls will help to prevent amplifier distortion and amplifier clipping... That's simply not true, UNLESS you set the gains at a level where the headunit cannot possibly drive the amplifier to full power.. And even if you were to find this magic spot for your gain controls then (A) you would have to turn that volume control FULL SWING to get your system loud and (B) since many music sources (or disks) are not all recorded at the same level, its likely that if you have a disk recorded lower then you cant get it loud at all! and if you have a disk recorded louder then you can still surpass your magic spot... So in reality searching for this magic spot is fruitless! Dont waste your time...
In the early 80s when high fidelity car amplifiers were just starting to make the scene I worked with a pretty crazy installer that was kind of legendary around these parts... I wont mention his name but he was pretty highly respected at the time.. Well anyway, this crazy installer had heard that the amplifier gain control was to prevent amplifier clipping.. (still widely heard today).. Well this crazy installer set up EVERY CAR WE DID to the point where the gain control was so LOW that if you turned the head unit all the way up the amplifier WOULD NOT DISTORT.. And of course if you did turn the headunit all the way up the system would just be getting loud...
Customers would find that some cassettes would be recorded at a lower level and the music just wouldn't get loud enough... The Crazy installer would FLIP OUT and tell the customer that a REAL AUDIOPHILE doesn't want his music to distort or be that loud! The customers were NOT HAPPY and came to me to say "Gee Eddie, I don't want to make the other guy mad but can you adjust my system so it sounds good and please dont tell the other guy? Of course I said yes, and some of those customers from back in the early 80s are still my customers and they are sending sending their children to me for work as well.
SO, you see the only way the gains can be used to eliminate clipping or distortion will also limit your top end volume! And for most of us it is NOT DESIRABLE to do so.
As long as this is not done, it is just as possible to turn your system up to FULL power and beyond to clipping no matter where the gains are set....
1helpful
Volume Problem with my TV and Home Theater system
I had the same problem with mine.The solution I found was to use an optical audio cable rather than the red and white RCA audio jacks. Hope this helped.
Sony F Tinitron 36" Volume lower in regular TV mode, higher in dvd mode
Try to disconnect the dvd andvr when watching plain tv. Thi may help..
Cheers!
IrishDruid
Popping & cracking noises
Is the popping noise coming from the speakers? If it is, lowering the volume to zero does not stop the popping from the speakers, then you have an audio output failure. If the sound is not from the speakers, you probably have a high voltage leak. If this is the case, are you in a moist environment or using the set near a window??
Can I connect a mini plug DIGITAL audio source into these?
Hello bobbobbob, These speakers would work great. First question is: Do you already own these speakers, or would you be buying them? If you already own them, then yes, use them, if not, a more economical solution would be the Bose Companion 2 speakers here: http://www.bose.com/controller?event=VIEW_PRODUCT_PAGE_EVENT&product=companion2_multimedia_index These are about half the price, and have exceptional clarity for someone like your aunt. They also will allow her flat panel TV to plug and play very easily. Please let us know if you need any additional information. Best regards and kudos for helping your aunt out! nightdiver
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
