PANDIGITAL 7-Inch Digital Photo Frame with 2 Interchangeable Frames (DPF701) Digital Picture Frame Logo
Posted on Mar 29, 2010
How to upload new photos - PANDIGITAL 7-Inch Digital Photo Frame with 2 Interchangeable Frames (DPF701) Digital Picture Frame
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 30, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
290
Points
Ok i am the engineer of Digital photo frame
1helpful
Windows 7 uploads all my photos on my camera instead of just the new ones
You need to delete the old photos in the camera - you can format the camera's memory discs prior to taking new photos.
Cannot upload pictures
eBay has a new photo uploader you may just need to give it a little more time. You may need to change your browser. I had some trouble with Internet Explorer I now have Google Chrome.
You may just need to use the ""Standard or Basic uploader.
Are you aware of eBay`s new photo policies, if not here is a link to the Photo center, check out the picture quality requirements.
eBay photo center
1helpful
2answers
How to upload photos to FB from Picasa program
Every photo that comes off my digital camera I import into Picasa before I do anything else with it, even if it's merely destined to end up on Facebook where I can share it with friends. Picasa Uploader utilizes the new APIs to connect Picasa directly to your Facebook account. To get started, take care of the following first:
  1. Get a Facebook account and make sure you can log in.
  2. Install the latest version of Picasa on your computer.
Now go to the Picasa Uploader page on Facebook and follow the instructions. You'll click on the Install Plugin button, which will launch Picasa with the Configure Buttons dialog open.
facebook_add_button_425x287.png Here you'll want to select the Facebook button on the left and then click the Add >> button in the center to add it to Picasa's button bar. You can then use the Move Up and Move Down buttons to change its position and finally click OK to save your changes. You may have to restart Picasa before you proceed. Once the button is installed, it's easy to use. To send photos from Picasa to Facebook, just select the photos you want and then click on the new Facebook button on the button bar in the lower right. A window will appear where you'll need to log into Facebook in order to give Picasa permission to upload photos to your account.
Now Picasa will prompt you to choose a Facebook album to put the photos in, or create a new one, and then it will upload the photos to Facebook along with any captions you've given them. Once it's finished, there's one more step: A browser window will be launched and you'll be taken to Facebook, where you'll have to "approve" the photos that have been uploaded. This is to prevent malicious applications from uploading photos without your permission. It's as easy as clicking on Select All and Approve.
Once your photos are uploaded, they live on Facebook just like photos you uploaded directly through Facebook's web interface, and you can go through and edit them, tag the people in them, and so on.
4helpful
2answers
How to upload photo to facebook
Hi. Go to you profile page on Facebook. Click on the photos tab located on the top of the center column, next to info. Click on the button on the top right: Create a Photo Album. Fill up the info and follow instructions to upload. You can choose the way you upload (Check selections on the bottom like for example: Simple Uploader). Once you photos are up you can select which one you want as a profile picture (there's a link under the photo on the right that says: Make Profile Picture). Hope that helps!
1helpful
3answers
How can i upload my photos on my profile?
Friendster explains in detail how to do this at this link:
Question
How do I upload my photos?
Answer
To upload photos to your profile, follow the steps below:
Option 1 - Using the new Java Uploader
Upload photos to a new album
- Log in to your account
- Click "Photos" from the navigation bar
- Click "Create Album"
- Browse and Check the photos you wish to upload from your computer
- Click "Upload"
Add photos to existing album/s
- Select the album where you want the photo/s to be added
- Click "Add Photos"
- Click "Upload"
Option 2 - Using the HTML Uploader
Uploading photos to a new album
- Click the HTML Uploader link at the bottom
- Select files to upload then click browse
- Click "Upload"
Adding photos to existing album/s
- Click "Upload"
5helpful
How do I upload my photo to facebook?
Sign in to ur facebook account. Click on Profile in the new page click on PHOTOS. Then click on the Creat a new Album button a new page will open. There enter ur album details. After that a new page will open(you might need to install java runtime environment) if you don't wanna use advance uploading(that requires java plugin) just scroll down and find the link try Simple uploader. after clicking on simple upload option a new page will where u'll find the option to upload your pictures. Click on Browse Buttons to add your pix and after adding pix check the I certify that I....... box and then click on UPLOAD PHOTOS and your photos will start uploading.
Thats it
For Further assisstance contact me at [email protected]
SMB
5helpful
I cannot upload or create new album or upload photos on new f/b
When logged in on the main Facebook page, click Photos under Applications, then Create A Photo Album.
This link here should work too: http://www.facebook.com/editalbum.php?new
Top PANDIGITAL Photography Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
