Some carpet cleaning machines have little balls that stop the water at a certain hight in the machine. could have come out and thats what is plugging the toilet
If it has a power flush (i.e hole about 1" in size opposite side of flushing direction) that hole gets plugged by minerals from the hard water, when it does the flush will be much weaker. To clean it, use a bent coat hanger and ream out the deposits as far in as you can reach. Then turn off the water supply, flush the toilet, then quickly pour one pail full of water into the toilet to drop the water level to minimum. Get "Lime Away" at H/Depot, pour in 1 cup and let sit overnight to eat the remaining hard water deposits from the bowl and power flush. In morning turn on water flush a few times, should wok good as new. Repeat anytime hole starts to get plugged.
You can try this, get a bottle of liquid plumber industrial or pro, and pour the entire bottle into the pipe in the toilet, when you remove the toilet cover you see a pipe that has a water line in it from the fill valve, if you can't pour the liquid into this pipe, then turn off the water to the toilet, flush it and hold the handle until all the water has emptied out.
Now while holding the handle, pour the bottle into the hole where the stopper is open, the hole where the water goes down.
Wait a hour, then take a bucket of hot water and fill the toilet water tank, flush it, do this again.
Now turn the water back on and flush. If the shower still over flows, you will need a plumber to come and snake the main line from the toilet down until the clog is cleared.
Unless he finds a close access near the toilet if this is on the first floor and he can do it from the basement.
From your description it sounds like the flushing orifices are plugged. The orifices are the little holes around the bowl or the big hole in the throat of some. A simple way to check if this is the problem is to get a bucket with aprox 2.5 gallons of water in it and pour it directly into the bowl and see if it goes right down. If it does, the orifices are plugged. Two of the most common causes of clogged orifices are hard water deposits and bowl cleaner cakes that drop in the tank. In the case of hard water deposits, we usualy acid clean the stool with muratic acid introduced through the flush valve. Be VERY careful when doing this, as the fumes are VERY dangerous and it can discolor colored porcilyn. May want to hire a plumber to do this. As for the cleaning cakes. You can pour some tap hot water through flush valve and dig into hole with wire hanger to remove as much as possible. I hope this helps.
Check water level in tank for proper height it should be about 5/8 close to top of stand pipe in tank or it should have a mark on it wher it should be.
You can adjust the flush valve to increase water height.
Don't know if you have calcium build up problems. If you do you could pour a calcium cleaner into the tank to try and clear up the problem. This would be the only way to possibly clean the enclosed area. Good Luck. Jeff
Sounds like something is either in the bowl stuck or down in the waste line. I would probably pull the toilet and pour water down the waste line to see if it backs up or set the toilet up on something and pour water into the bowl to see if it comes out. At least it will help to find out where the problem is. Have you lost anything recently that might have fell in the toilet. Did something come off of the plunger and get stuck in the bowl?
