That noise is probably the starter solenoid rattling because the battery charge is low. Start out with a jump or make sure the battery is fully charged up.
is it making any noise at all, if it makes whineing noise but not crank, its a timing issue, if it has no noise at all it is likely the started, try banging on it when someone turns the key
Make sure your battery is fully charged and all battery connections are clean and tight. If the vehicle still makes the clicking noise when you try to start it, then it is your starter solenoid.
1st check the connections at the battery for corrosion, clean and make sure you have a tight connection. Bring the battery to a parts store, they will check it's condition for free. It may be bad, and all you need to do is replace it. If they find it's not charged fully, bad connections at cables or alternator may be to blame.
the clicking noise you are hearing. is generated from low voltage to the starter. the solenoid will not stay closed. to bring primary voltage to starter motor. solution take battery to local parts store have it fully charged, then load tested. the fully charged battery, should be the answer.
