NAD T765 Logo
Posted on Mar 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
This may not be an actual problem. I've observed after performing a successful Audyssey calibration that a few things seem odd. My large (Paradigm Monitor 11) front speakers are now considered 'small,' while the small surround speakers are 'large.' Also, Audyssey has reset my speaker distances. The LF is 15 feet away but was reset to 22 feet. I have a pair of subwoofers each 10 feet away, but their distance now shows up as 30 feet. Is this OK? Should I leave the Audyssey values alone?
Mike LaPres
Level 3:
  • Master 757 Answers
  • Posted on Mar 29, 2010
Mike LaPres
Master
Level 3:
Answers
757
Questions
0
Helped
278235
Points
2002
If it sounds normal, then yes leave them as they are.
But there may need to be an exception made.
The distances are set the way they are for the proper advance or delay in milliseconds of the sound arrival at the listening position.
The system calibrated your speaker settings based on how each channel's frequency responses measured at the listening position. Room acoustics and channel positioning greatly affects this. The settings it made in the system can be a best case scenario compromise that MAY not be good for your surround speakers as it can be delivering signal to them that they were not designed to handle; in which case it is best to increase the crossover value of those speakers.
tip
SERVCIE MODE
Panel Check
You have to check Panel Maker Because of different adjustments as follows. First of all, Check the label rating!
1) Label Rating File
- LCD PANEL MARK
A:ACER(AUO) S : SEC C : CMO
* If not printed you could consider S(sec) panel mark.
Method of Color Calibration (AV)
1) Apply the NTSC Lattice (N0. 3) pattern signal to the AV IN 1 port
2) Press the Source key to switch to "AV1" mode
3) Enter Service mode
4) Select the "Calibration" menu
5) Select the "AV Calibration" menu.
6) In "AV Calibration Off" status, press the " RIGHT ARROW" key to perform Calibration.
7) When Calibration is complete, it returns to the high-level menu.
8) You can see the change of the "AV Calibration" status from Failure to Success.
Method of Color Calibration (Component)
1) Apply the 720p Lattice (N0. 6) pattern signal to the Component IN 1 port
2) Press the Source key to switch to "Component1" mode
5) Select the "Comp Calibration" menu.
6) In "Comp Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "Comp Calibration" status from Failure to Success.
Method of Color Calibration (PC)
1) Apply the VESA XGA Lattice (N0. 21) pattern signal to the PC IN port
2) Press the Source key to switch to "PC" mode
5) Select the "PC Calibration" menu.
6) In "PC Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "PC Calibration" status from Failure to Success.
Method of Color Calibration (HDMI)
1) Apply the 720p Lattice (N0. 6) pattern signal to the HDMI1/DVI IN port
2) Press the Source key to switch to "HDMI1" mode
5) Select the "HDMI Calibration" menu.
6) In "HDMI Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "HDMI Calibration" status from Failure to Success.
FOR MORE DETAILS CHE THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB FIND MODELS OR USE DROP DOWN MENU
1helpful
How do I connect the audio from a Panasonic to p50-s1 to a marantz nr1403 so that I get surround sound audio?
The Audyssey setup does not use any audio from the TV. Audyssey is started automatically when you plug in the calibration microphone. Once you start the setup, it will output a calibration tone to each speaker. (Read the Audyssey setup instructions.) There is 1 digital audio optical input on the back of the NR1403. You will need a optical digital cable for the connection. Once connected, you'll need to use the input setup menus to select that digital sound input to go with the video input you are watching. Check page 15 of the manual.
S4100 Coolpix. memory messages when reviewing photos on SDHC
No, your camera cannot use SDHC cards. It's only a 4 megapixel camera so a 2GB SD card will hold hundreds of pics.
On the Zebra it was printing 4x13 labels without a problem. However when I tried to print a 4x6 label it still thought there was 4x13 stock in the printer. I played around with the label format size, even...
I think this is more related to the calibration of the label each time you change the new label size. I use ZM400 and your printer should also have the same setting. Under setting, put the When Head Close setting to Calibration. This will let the calibration perform automatically when ever you load a new label size and close the print head. Well 2 label will be lost every time.
Severe crackling during recording
.i assume the crackle you'r getting it when you are using the built in mics? i;m still in the process of troubleshooting my 2g but this is what I've got so far....the line in dosn't suffer from the crackel, so it cracked here open , didn't see any obvious problems on the board so i disconnected the black wire from one of the built in mics and this is what i found: odd and strange..... the crackle went away but i haven't tested that in depth yet 2. when recording it looked like i was getting some thing on both tracks odd.. thought 1 channel would be dead. anyway i got tired and put it away and haven't gotten back to it yet but about time i did so hopefully this weekend . hopefully i'll have some more useful info.. now a note on my take so fare as to where the crackle is coming from , bear in mind i've only had about 3 hours with the 2g so far so still getting acquainted. i'm getting the feeling it might be associated with the ACG or the record level auto calibration or clipping etc.. because i noticed that it seems like its starting ,checking levels, and setting things the a spike and it resets and starts over again. how ever the pattern is to random from what I've seen so far to to be anything concrete
DCS T70 LCD does work properly .I mean to say if i try to use one function another function gets started instead of desired function
Based on the information you've provided, it seems that the touch screen panel is not aligned. You can try Calibrating the touch screen to resolve the issue.
Calibration option is in the Main Settings 1 Menu of the Camera. Calibration option enables you to perform calibration when the touch panel buttons do not react at the appropriate points where you touch. You can use the paint pen, touch the X mark displayed on the screen. The X mark moves on the screen. Once the calibration option is finished successfully, the touch screen should work.
The Calibration option can be done only if the Menu is accessible.
You can also perform a power reset before performing the Calibration.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
This should resolve the issue.
Thanks for using Fixya.
Audyssey vs Direct switching on Onkyo SR606
Audyssey is the licensed feature this receiver uses for room and dynamic equalization. It sounds like the Audyssey process is activated. The manual says the Audyssey indicator "flashes during automatic speaker setup".
Has this unit ever worked or are you still setting it up?
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
