If u have made sure both ends of the power cord are attached and plug in properly and that the outlet has juice if so it is either your power supply or power button with an issue or short if both those are checked out and fine than it may be a software or motherboard issue in which case you would need to contact the manufacturer
The Turn Signal Indicator
The Sidemarker Lamp
The Sideview Mirror (Pontiac Thunder only)
The turn signal switch also sends a separate on-off signal to the Daytime Running Lamps (DRL) control module, which relays the signal to the appropriate front turn signal. The front turn signals are grounded at G101 and G102. The rear turn signals are grounded at G401. The sidemarker lamps are grounded through the corresponding front parklamp.
The sideview mirror turn signals are a bank of LEDs placed behind the mirror glass.
The hazard lamps operate on battery voltage. The HAZARD fuse supplies battery voltage to the turn signal switch. When the hazard switch is pressed, the turn signal switch sends battery voltage to the hazard lamp/turn signal flasher, which sends an on-off signal to the turn signal switch. The turn signal switch send the on-off signal to all the turn signal lamps, causing all the lamps to flash including both IPC turn signal indicators. The hazard lamp/turn signal flasher is grounded at G200.
When the parklamps are ON, the sidemarker lamps receive voltage from the park lamp supply voltage circuit and illuminate. The sidemarker lamp is grounded through the corresponding rear turn signal. When the turn signal switch is place in the left or right hand position, the rear turn signal illuminates and the sidemarker lamp will loose its ground, causing the sidemarker lamp to turn off when the turn signals are on and to illuminate again when the turn signal is off.
Which blub an socket did you replace ? check the other blub ? The switch and or the flasher module can cause this problem .
Replace the turn signal switch. Refer to Multifunction, Turn Signal, and Hazard Switch Replacement - On Vehicle in Steering Wheel and Column.
Did you complete the replacement?
Which
Thanks for the suggestions so far! This problem occured after the monitor stopped working properly then displayed an image resembling an interference pattern. The prevailing situation is that the computer will not switch on but I am getting lights, the screen momentarily displaying 'no signal' and noise (that is the fan only)!
Are you ready to open the computer up? Here are a few steps to try before taking it to the computer repair shop; First, Unplug the computer for ten minutes and then plug it back in. *Does it do nothing? If there are no lights no noise etc., then it is the power supply. *Lights, but no noise or screen? - This is more commonly the motherboard. This can still be a voltage out on the power supply, or bad mobo all together *Lights, noise but no screen? - The most common, bad video card. First try another monitor, then try a new video card. You should at least see bios (the screens before windows starts) Please post with the results, follow up question or leave good feedback if this helped.
could be a number of things 1 it isnt plugged in 2 your power supply 3 your power button 4 your cpu it could be a number of things try posting a little more info
